engine die instantly
Old Mar 13, 2009 | 11:31 AM
king_pin's Avatar
Default engine die instantly
i just did a d16y8 swap in my ej6
when i start the engine, it just cut if self off instantly
if i press the gas pedal i can keep it alive but as soon as i let go it shut down
any clues or reason why its doing this?
Old Mar 13, 2009 | 11:36 AM
davefromPA's Avatar
Default Re: engine die instantly
sensor malfunctioning.
Old Mar 13, 2009 | 11:37 AM
Former User's Avatar
Is the CEL ON?
king_pin's Avatar
what sensor is it
Old Mar 13, 2009 | 11:38 AM
king_pin's Avatar
yeah cel is for the canister and o2 sensor but iono why its a new o2 sensor
Old Mar 13, 2009 | 11:39 AM
davefromPA's Avatar
Sorry that was vague. MAP sensor malfunction. or MAP and TPS switched.
Old Mar 13, 2009 | 11:42 AM
king_pin's Avatar
its okey i'll go switch that out later tonight
thanks in advance
What are the specific CEL codes?
Old Mar 13, 2009 | 11:43 AM
bmxmacdaddy's Avatar
tps? yeah what codes are they? #'s
Old Mar 13, 2009 | 11:50 AM
king_pin's Avatar
i lost the paper for the cel code but
the code was for like a fuel vapor something ( needs a different canister)
and the other was for the primary heating sensor o2 sensor
Old Mar 13, 2009 | 12:01 PM
king_pin's Avatar
i'll get the code later on sorry about that
Old Mar 13, 2009 | 12:02 PM
ferngsr's Avatar
check your oil pump ! ! happen to me twice ..... my oil pump took a dump
Old Mar 13, 2009 | 12:10 PM
You can pull the codes yourself at home (see forum CEL sticky).
As mentioned, also verify that connectors for the throttle body sensors -- TPS and MAP -- are not switched and connected tightly.
Old Mar 13, 2009 | 12:29 PM
king_pin's Avatar
i'll go check the tps and map right now
and see what happen
Old Mar 13, 2009 | 12:41 PM
king_pin's Avatar
i try to switch both the tps and map but it still does the same thing
it start then just shut it self off
VeeSykkz
14
Dec 16, 2014 07:31 AM
myst
May 18, 2010 10:52 AM
97civic07gsxr
Mar 27, 2009 05:11 PM
Groove_D
Jul 11, 2007 12:30 PM
