recommend about which welding..should i ..
hello to everyone
im plannin to buy the mig welder so i dont know which its good for me since i only have like 400 dollars with me ..
will this mig welder is good...
http://store.cyberweld.com/hobhan135wit1.html
Hobart Handler 140 MIG Welder with Economy Cart
Includes Hobart Handler 140 MIG welder with all accessories and Economy Cart with Cylinder Rack and Cable Storage Shelf
Cart will handle one gas cylinder up to 7" in diameter, max cylinder weight 75 pounds
The Handler 140 MIG welder operates off 115 volt standard household current for maximum versatility. Comes ready to weld with or without shielding gas, no additional kit required. With an amperage output range of 25 - 140 it easily handles a broad selection of solid mild steel or stainless, flux cored and aluminum wires.
please let me know if any one of this member using this mig welder and please put the comment on it. thanks
from vic
from vic
alright, right now i have like a regular welding mig is 90amp but its .008mm wire and it aint good so which is the best size i should get for thick one? btw, its not with tank just a electric
still gonna need a couple hundred for gas and cylinder, flux-cored sucks big time. I bought one like for my first welder, it's better than nothing. it won't do much more than 3/16 or maybe even 1/8. rarely use it for thick stuff but does slightly thicker with flux-cored wire.
but right now, i have welding which its only electric, no gas tank, nothing at all..but the wire of flux core is .008mm which its too thin but wuts the best thick size for that?
i would not use flux-core on body panels but go with a .030 flux-core, 110 machines like the thinner wire + the thicker wire gives more resistance that can make it harder not to blow through thin sheet.
otto
Sep 17, 2005 11:44 AM
Boosted96EK
Welding / Fabrication
May 19, 2005 12:31 AM
