how much gas can an ls hold
How big is the 2000 Ls gas tank is it 10 gallons 12 or 14 ? and waht type of mpg are you guys getting i think i'm getting 20mpg now withmy intake before i was getting like 15
post from a week ago: https://honda-tech.com/zerothread?id=246244
I get 26 mpg with mostly highway driving before my intake. I am still using the same tank of gas since my intake, right now it looks like 22 mpg because the heavy AC usage and hard drive to test out the intake. I think the next one will be much much higher (I am hoping 30 mpg).
Yup, 13.2g.
How precise is your mileage estimate? 15 or 20 mpg is horribly low. I get 29-30 and that's with a lead foot. A/C will drop me to like 26-27 if used a lot.
damn somthing is wrong then cause i'm def not getting more than 20mpg i've never seen more than 180 to a full tank !! and tahts not even driving her hard ?? what could be wrong ?
[Modified by RacerXintegra2k, 10:41 PM 8/12/2002]
i ride my tank till its on the E. it takes ~11 gallons to fill her up and i hit about 320-340miles on it gives me bout a 30mpg ratio. but then again most of my driving is highway
I shall stop incorrectly posting.
2000 LS Integras (I am the owner of one) have a 13.2 US Gallon gas tank.
Weston and the post prior to his are correct.
[Modified by WOTTEG, 3:11 PM 8/15/2002]
Do not incorrectly post.
2000 LS Integras (I am the owner of one) have a 10.X gallon gas tank.
Weston and the post prior to his are possibly for a different year LS integra.
The 2000 integra has the same fuel capacity which is 13.2 gallons. Im guessing if you probably think it has 10.X gallons due to you only filling up 10.X gallons.
I assumed you didn't have your manual
well, check in there cause it is 100% accurate info for your car. But I am pretty sure it is 13.2 for all models.
Helm's and my owner's manual say 13.2 US Gallons.
My window sticker says 10.2.
Looks like someone made a typo, and I made a fool out of myself for it.
Apologies all around, I'll edit my previous post.
lunarone
Dec 12, 2006 02:55 PM
low430
Oct 2, 2005 01:53 PM
