Gt35 Coolant Lines???
I want to upgrade my turbo setup from a sc-61 to a gt35. I want to know where everyone running a water cooled turbo taps for the coolant, and where it gets returned. Pictures would be great thanks!
^ one slight problem with that. he may have remove all his a/c parts.
check out BLD industries. they have a front block tap and a return to radiator set up. its like 130 bucks. its what im using.
If you don't have an automatic transmission, you can run it through the portion of your radiator that would be used to cool the AT fluid. On manual Preudea there are plugs and this section of the radiator is unused.
And the return?
