need help on removing broken bolts
Old Mar 11, 2009 | 06:56 PM
ryanevansoh's Avatar
Default need help on removing broken bolts
ok i was swapping cams in my b18a1 and when i went to tighten the bolts back down they snapped because the torque wrench i was using was unknowingly broken ok my question is how can i get these bolts out? they are the ones circled
Old Mar 11, 2009 | 07:27 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: need help on removing broken bolts
1>Soak them with PB BLASTER penetrating oil
[Allow them to soak overnight or as long as possible]
2>Center punch with a quality automatic center punch
3>drill a small pilot hole in the center
4>Apply heat to the boss around the broken fastener
5> Use a low speed drill with left-handed drill bits
or you can also use broken bolt extractors but be careful..
If that sounds out of your range of capability,
I would suggest a reputable machine shop..
Old Mar 11, 2009 | 08:17 PM
thanks for the help, i think im gonna try the broken bolt extractors cuz its sound much easier. but do you think they will be able to fit in the bolt hole?
Old Mar 11, 2009 | 08:21 PM
jhammond_82's Avatar
Reject Papi
why didn't you stop after the first one. maybe two, but three!! i suggest the machine shop idea.
Old Mar 11, 2009 | 08:41 PM
user 93082343's Avatar
Why wouldn't you stop after breaking on? Once one is broken you have to take it all apart to take the broken bolt out anyways.
-John
Old Mar 11, 2009 | 08:54 PM
ok well i thought the torque wrench was working, til i realized it broke a few. just a stupid mistake. im gonna try the bolt extractor idea though
Old Mar 12, 2009 | 12:07 PM
88DXCRX's Avatar
Originally Posted by ryanevansoh
im gonna try the broken bolt extractors cuz its sounds much easier. but do you think they will be able to fit in the bolt hole?
Yes,thy make them in small to very small sizes.
PS>that bolt is a 6mm in size..
Also sometimes,
If the bolt is not "seized" or
"bottomed-out" in the hole,and will turn freely,
You can take a dental pick or a flatblade
screwdriver and just twist them out..
Old Mar 12, 2009 | 02:56 PM
ok thanks for the help. i bought a bolt extractor kit so now im gonna try to get them out
Old Mar 12, 2009 | 05:45 PM
nihad's Avatar
try the easy out craftsman sells them you can get a smaller size us a drill center drill also and then us the easy out if it doesnt work get a 50$ b18b1 head get the newer style head...
HotCheetos
10
Dec 11, 2010 09:07 PM
Yelowfever
Jul 10, 2007 08:06 PM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
syndicate43
Nov 25, 2002 05:49 PM
