Help me I.D. some gsr parts please!
Old Mar 11, 2009 | 01:33 PM
90Rexx's Avatar
Default Help me I.D. some gsr parts please!
Ok so i need some positive identification on a sensor and where the vacuum lines go.
Above the throttle body ( not bolted on it ) on a stock 94-01 gsr manifold is a sensor ( 2 wire ) that has a 2 vacuum lines going to it. the lower vacuum line goes to the plenum.... the upper vacuum line goes to a little plastic hat type thing, that on my engine is disconnected. can somene tell me where this hat/ vacuum line goes... and what sensor this is??
now second, on the thermostat housing, theres 2 coolant lines coming off of it. the big line goes into the intake manifold, but where does that smaller line go into??
please someone take 3 minutes to run outside and look at ur engine to help me out!
Old Mar 11, 2009 | 02:15 PM
94EG8's Avatar
Seagull Management
Default Re: Help me I.D. some gsr parts please!
Evap purge solenoid, one vacuum line goes to the intake manifold, the other one goes to the charcoal canister on the firewall.
I haven't got a B-series engine here to look at but I suspect that line either goes to the IACV or the fast idle thermo valve.
Old Mar 11, 2009 | 03:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The larger hose on the thermostat housing is the bypass hose that connects to a large port on the intake manifold flange (#9 in the diagram). The smaller hose #7 connects to the hardline that is coupled with your intake breather pipe, and then connects via hose #14 to a port near the upper radiator hose connection near the head.
And here's a pic of my OBD1 throttle body:
Old Mar 11, 2009 | 05:59 PM
90Rexx's Avatar
awesome lol that answered everything perfectly. much thanks to both of you for your help!
GameBoyeas
10
Jun 5, 2017 09:14 AM
4dooritr
Nov 8, 2007 09:23 PM
agy2k2
Aug 11, 2006 05:30 AM
93solsigsr
Apr 15, 2003 05:25 AM
xci_ed6
Aug 10, 2002 05:35 PM
