H2b help!!!!!!!!!!!!!!!!!!!!!
Ok im doing a h2b swap on my 91 EF Hatch but i ran to a problem.
the H2B KIT from evolution comes with a template to grind down the block
to make clearance for the axle but when i did it made a small hole almost right
on the corner of the block but when i leaned the block back Oil came out the hole so i took the oil pan out and it went tru but everthing else is good expect that little hole. DID ANYBODY RAN INTO THIS PROBLEM?
actually i was just looking at it the hole is on the oil pump... right on the corner...so i think ima just cover it up with something because there is no crazy pressure there...but thanks..i thought it was on the block but wen i look at it again is not so i think ill b ok
DOWNwithHT
Aug 17, 2007 05:36 PM
