brake problem..
Old Mar 11, 2009 | 07:59 AM
limit's Avatar
Icon2 brake problem..
Okay so i just got my 95 ls integra auto and when im driving down the road and hit the brakes they brake good until im completely stopped thats when the brake pedal starts going down slowly...i checked for any leaks and no leaks, then i bled the system and everything checked out okay....so i decided to check one more time under the hood and saw that the abs system was cracked and didnt have any fluid, could this be the reason y the brake pedal goes down to the floor when im at a stand still
Old Mar 11, 2009 | 08:12 AM
mickeey's Avatar
New User
Default Re: brake problem..
bad brake master cylinder
Old Mar 11, 2009 | 08:50 AM
civicgsr's Avatar
x2 definitely. The seals are good enough to give you line pressure, but are allowing fluid to slip by causing the pedal to sink.
Old Mar 11, 2009 | 09:08 AM
limit's Avatar
thank you ill check that when i get home
JONESER
Feb 3, 2012 07:28 PM
91integraLSVTEC
Jul 25, 2009 07:09 PM
spintboy
17
Jan 3, 2008 08:49 AM
FourthGenHatch
15
Oct 5, 2002 07:53 PM
dnt94civic
Jun 7, 2002 05:04 AM
