gsr brakes on eg hatch question...
ok so ive researched and came to the conclusion that if i go through with the whole gsr front and rear brakes on my eg (dx model)...i should put a bigger brake booster and master cylinder(15/16" or 1") and 40/40 proportional valve from a non-abs teg...my question is...is it okay for me to use a brake booster and brake master cylinder from a 95 civic EX that came with abs???
any help is much appreciated...
Understand this, in the case of an ABS 4 wheel disk eqiupped civic, the brakes are the same ones used on an integra. So yes, you can use those parts. The only issue comes up with the odd sized fitting for the rear brake line on the MC. It's huge compared to standard fittings. What you can do is get the hard line from the same civic and you should be okay.
Going with the integra MC and booster will definitely help pedal pressure but is not necessary.
-Alex
-Alex
Fo-Do Fanatic
Aug 9, 2010 02:35 AM
EJ2_B16
Aug 20, 2004 02:34 PM
