Smog Test CRX Si w/B16 Fails
Trying to get this CRX to pass smog; Setup is simple
Body: 1991 CRX Si
Engine: JDM B16A 92-93 Integra XSi
- DC Sports Headers (CARB Exempt; Tagged)
- AEM Cold Air Intake (CARB Exempt; Tagged)
- AEM Fuel Rail
- AEM Fuel Pressure Regulator (Stock PSI (80psi))
- New Catalytic Converter ( Magnaflow UNIVERSAL-FIT CATALYTIC CONVERTER )
- New O2 Sensor ( Denso Oxygen Sensor )
- New Exhaust ( ES Tuning Systems Oval Universal Muffler )
Tried to get the above setup smogged this past weekend and failed horribly on the "NO (PPM)"
I use 91 octane fuel (Chevron)
Test Results:
Current To-Do List:
Anything else to add, check, replace, etc?
Thanks!
:Location: Southern California
Body: 1991 CRX Si
- AEM Fuel Rail
Test Results:
Code:
| %CO2 | %O2 | HC (PPM) | CO% | NO (PPM) | Test | RPM | MEAS | MEAS | MAX GP MEAS | MAX GP MEAS | MAX GP MEAS | Results 15 MPH | 2111 | 13.50 | 1.46 | 134 308 127 | 0.82 2.32 0.03 | 847 2070 3704 | G POL 25 MPH | 2452 | 13.30 | 1.51 | 108 258 66 | 0.71 2.21 0.00 | 786 1870 3330 | G POL
- Check and Verify timing
- Install new Honda OEM Fuel Injectors (on-order)
Thanks!
i miss my crx, i realize now how much i would use this site back in the day.... when you wanna install?? lets do it this weekend, i gotta do **** to my car too
did you try to use GARUNTEE PASS EMISSION BOTTLE. its p2p. just go to a auto parts they probably have it. i dont know the exact name but the two names i gave u will be 2 good hints.
Harder to diagnose are elevated oxides of nitrogen (NOX) emissions. as your readings are HIGH for sure...over-advanced ignition timing maybe.. NOX readings will rise sharply during acceleration and will peak a few seconds after the cruising speed is reached. If the EGR system fails to recirculate exhaust back into the intake manifold, combustion temperatures will rise causing an increase in NOX. The higher temperatures may also cause some detonation (spark knock) to occur, which may be audible when the engine is under load. Causes of elevated NOX emissions during acceleration include:
Defective EGR valve;
Leaky EGR valve plumbing or control solenoid;
Carbon deposits in EGR manifold passageways;
Carbon buildup on pistons and in combustion chamber;
Over-advanced ignition timing;
Defective knock sensor;
Engine overheating (check thermostat, fan, coolant level);
Exhaust restrictions.
Some of these may not apply, but I thought I would just be thorough..
its been a while, but from what I remember the jdm b16a1 is supposed to have pretty high NOX out of the gate no?
based on the above posters list, the only issue I had that I did not try to resolve was carbon buildup on the pistons and in combustion chamber. Was gonna try seafoam but went with the less invasive guarantee to pass instead.
OP: as for your NOX problem.. it seems that many people get better results after changing their CAT so maybe you could try that in combination with some of the other suggestions mentioned
good luck!
Well after many things going wrong:
Stripped threads on the oil pan. End Result: Replacing the oil pan
Exhaust header stud breaking on the head. End Result: Purchased Craftsman 10 Pc. Screw Extractor, drilled out stud and used extractor to get it out, replaced with new stud; like new.
Breaking a stud on the fuel rail. End Result: removed with vice grips and replaced with a bolt instead.
Also yes I used a torque wrench... I own a Snap-On Torque wrench and a Craftsman Torque; so no speak of "use a torque wrench" or "dont go crazy on the bolts", etc, al
Replaced the Fuel Injectors and used the "Guarantee to Pass"; but I didnt.. lol... see results below:
Underline - Values went down from Previous test
Italic - Values went up from Previous test
Previous Results:
Anything else I could possibly try?
Code:
| %CO2 | %O2 | HC (PPM) | CO% | NO (PPM) | Test | RPM | MEAS | MEAS | MAX GP MEAS | MAX GP MEAS | MAX GP MEAS | Results 15 MPH | 2258 | 13.32 | 1.65 | 134 308 70 | 0.82 2.32 0.01 | 847 2070 3307 | G POL 25 MPH | 2484 | 13.10 | 1.95 | 108 258 47 | 0.71 2.21 0.01 | 786 1870 2949 | G POL
Previous Results:
Code:
Previous Results:
Code:
Previous Results:
Code:
Any exhaust leak after the cat you shouldn't need to worry about unless it is a huge hole and causing an sample diulution---sorry bout the spelling!
The thing I notice is your O2% is high. Which usually means either you have an exhaust leak or the cat is not using the O2 to tear down the elements. I would concentrate on this. If you have a leak the cat will not get hot enough for it to work correctly, or more importantly if the leak is before the O2 sensor it will not provide the ECU with the correct information and messing with your air/fuel ratio's.
Any exhaust leak before the cat is bad news.
Did you replace the donut gasket when you put it on?
Are you using the stock connection with the springs? You might need to add a washer or two to tighten up the springs. You add them on top of the springs and put the bolt thru.
... This might be where I went wrong... Yes stock connection with springs, but I'm sure that gasket is shot... Funny the small things you can forget about
get a newer stock honda cat and make sure its real hot before the test. really beat on it to get the temps up. dont let it cool off or sit before the test. get it hot and drive it right in. those hi flow cats dont work that well for emissions
X2 on the cat. went through all this horseshit when i did mine.
Almost the same mods exactly......its your cat, heat that bitch up.
I tested 17 times before it passed, and its a fresh build.
/thread
So I indeed had an exhaust leak downpipe where the header meets the CAT; turns out the old gasket had cracked in 4 different places... It was a ceramic gasket so my guess is the heat and the fact that it didnt seal completely caused a weak point, thus, the cracking.
I ended up ordering "1993-1997 Honda Civic del Sol Bosal Exhaust Gasket" Price: $17.09 Part #: BO256303
Since this gasket was probably the proper gasket to be using; the prior gap i had was too big and it was a pain in the *** to get the springs clamped down with vice-grips so i could tighten the bolts. With the new gasket in place I took it for a test drive and could tell the difference immediately.
Unfortunately I believe the smog still failed... I took it to a shop where I had full knowledge that the "magic touch" would be given to get it to pass if it would not do so on its own... I opted for the later...
...And thats that...
CRX805
17
Dec 11, 2009 06:07 PM
HuGEN
Aug 27, 2002 08:02 AM
