wideband wiring ?
Old Mar 10, 2009 | 02:10 PM
downforlow's Avatar
Default wideband wiring ?
hi all, new to civics and turbos so this is a learning experience here.
first off i have an LSU 4.2 bosch wideband and i'm not sure that its hooked up right. i have the red IP wire spliced to the o2 spot on the ecu, the yellow VS\IP wire goes to the other connection. the grey and white are hooked up to the heater and the black VS is not hooked up to anything.
is this correct or should i be doing something else to make this work.
im running the hondata S300 and just want to see the correct A\F on that for tuning, dont want to buy more stuff unless i have to.
Old Mar 11, 2009 | 08:30 AM
Spunkster's Avatar
Default Re: wideband wiring ?
Unless you have purchased a wideband controller such as one of the ones made by PLX Devices, just hooking up a wideband sensor to the ecu will not do anything except maybe damage the sensor and ecu.
http://www.hondata.com/techplxwiring.html
Old Mar 11, 2009 | 04:49 PM
Tomdata's Avatar
perfect answer
Old Mar 11, 2009 | 05:21 PM
Bangher4$'s Avatar
sounds like he just wants to datalog.
Why cant he just mod the ecu to see in 0-5v?
how is that going to damage anything?
Old Mar 12, 2009 | 08:37 AM
Spunkster's Avatar
Can you just mod a standard DVD player to play BluRays?
Old Mar 12, 2009 | 01:58 PM
Ls_dx's Avatar
Old Mar 12, 2009 | 04:02 PM
Bangher4$'s Avatar
Maybe? i dont know anything about bluray
I thought there was a page on pgmfi that shows how to do an 0-5v o2 Input Mod
Old Mar 12, 2009 | 05:53 PM
downforlow's Avatar
thanks spunkster, thats a good link didn't see that before.
Old Mar 13, 2009 | 08:48 AM
THC07's Avatar
http://www.marklamond.co.uk/tech-hon...t/o2-input.htm
Old Mar 13, 2009 | 04:09 PM
Tomdata's Avatar
wow
another perfect answer
Old Mar 14, 2009 | 05:33 PM
downforlow's Avatar
thanks thco7, now i just have to track down that resistor i guess. has anyone done this mod here?
Old Mar 15, 2009 | 06:12 AM
THC07's Avatar
you can email me if you need any info, jimjones07@sbcglobal. net
21
Jan 3, 2011 06:40 AM
roachsboosted16
Engine Management and Tuning
Jun 5, 2008 05:20 AM
DeezNutts
Mar 19, 2006 11:25 PM
5thGenFanatic
Aug 25, 2005 04:08 AM
Rain_man
Mar 18, 2003 03:53 PM
