LS distributor question
they are all the same obd2 and obd1.. the only difference is the wiring.. obd1 had 2 separate wiring plugs where as obd2a has 1 big plug.. they all use the same wires.. you can actually cut and solder them to fit into an obd1 wire harness..
here you go buddy..
http://www.phearable.net/tech/wiring...istributor.jpg
here you go buddy..
What car do you have btw?
As for a 93 civic.. is it an si model? or standard vx, cx etc.??? well if its the si model then your in luck.. You dont have to modify your engine harness for the sensor plugs to work. But if you want you can always get an obd1 gsr engine harness.
Cractos
Jul 26, 2005 10:47 PM
