High pitch whistle coming from transmission?
Old Mar 10, 2009 | 11:08 AM
raidacaipo's Avatar
Default High pitch whistle coming from transmission?
I swapped in another motor using a hydro b16 transmission. I start the car and hear a high pitch whistle coming from the tranny at all times! It hurts my ears when I stick it next to the starter. I did not replace my throw out bearing (stupid me) but when I step down on the clutch that noise does NOT go away. I want to know if its the throw out bearing or not before I go and take off my transmission and replace it. Any suggestions?
Also my idle has been going up and down. I adjusted my tps already and checked for any vacuum leaks from the intake manifold. Non whatsoever.
Old Mar 10, 2009 | 11:11 AM
DRAMA's Avatar
Default Re: High pitch whistle coming from transmission?
Could also be the main shaft itself. The next time you have the tranny out, see if there's a lot of play on the main shaft. Otherwise, it's the clutch release bearing.
Old Mar 10, 2009 | 11:13 AM
raidacaipo's Avatar
so you would say its my transmission eh? therefore I gotta take it off no matter what then I can see what the problem is.. this sucks
Old Mar 10, 2009 | 12:21 PM
raidacaipo's Avatar
need more suggestions
Old Mar 10, 2009 | 01:09 PM
94EG8's Avatar
Seagull Management
The release bearing only turns when you begin to depress the clutch pedal and the release bearing contacts the fingers on the pressure plate.
What it all means:
-If the noise is there when the clutch pedal is up (clutch engaged) the release bearing isn't turning.
-The noise is still there even when the clutch pedal is depressed, interesting because at this point nothing inside the transmission is turning. This should eliminate any internal transmission bearings.
What does this leave us with?
-The pilot bearing, the only problem with this is that once the clutch is fully engaged the transmission input shaft and flywheel should be turning at the same speed (meaning the pilot bearing shouldn't be turning.
Check your free play, I suspect the release bearing is bad and turning all the time due to there not being enough free play.
Edit, when I initially read the OPs OP I figured this was the same old question I see every week, this one is a little different, the noise is there all the time.
Old Mar 10, 2009 | 01:32 PM
raidacaipo's Avatar
What it all means:
yes I will definitely check the free play as soon as I take off the transmission. Thanks for the advice. Ill get back to yah maybe later on tonight!
numotive
Sep 11, 2005 10:31 PM
ultimatehonda
Mar 8, 2004 08:58 PM
Drew96EJ
Sep 23, 2003 10:09 AM
UNVMYR
Feb 27, 2002 11:37 AM
