Tranny Noise....TB or input shaft bearing?????
Ok I have a 00 si. I replaced my clutch about 7k miles ago and ever since so at idle I hear this noise. I only hear this at idle, and if the engine speed changes(a/c kicks in, or i give it gas) then it goes away. I am thinking the throw out bearing is barley touching the pressure plate and is cause that noise. But I have also heard that the input shaft bearing has similar symtomes. The noise started happening after the new clutch went in, and everything was replaced including a new throwout bearing. Also I do not hear any noises while I am driving. The only odd noise is at idle with the clutch engaged....and if the engine speed changes it goes away and then comes back when the speed decreases. Any help will be great...
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">If it was the ISB it would only rattle when the clutch is up, and go away when you press it in...</TD></TR></TABLE>
Yeah thats when it happens....but its not constant...it goes away a bit when the engine speed changes. Could this be the early stages of a bad ISB?
Risky Business
Re: (ultimatehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda »</TD></TR><TR><TD CLASS="quote">
Yeah thats when it happens....but its not constant...it goes away a bit when the engine speed changes. Could this be the early stages of a bad ISB? </TD></TR></TABLE>
Yes
Yes
Re: (BauleyCivic)
That cant be good. What causes this to go bad? I have noticed this since I installed the new clutch...I have also read that the same thing has happened to other people while installing a new clutch???
Risky Business
Re: (ultimatehonda)
Popping the clutch wears it out, or in the case of a new clutch, harsh engagement. Most people upgrade to a clutch that is extremely strong and stiff, so a lot more pressure is put on the ISB during engagement. Most of the time a 100,000 mile bearing can't hold up against a clutch with 150% holding capacity over stock. This is why I don't like ACT
Risky Business
Re: (ultimatehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda »</TD></TR><TR><TD CLASS="quote">Yeah I only have 48k and the clutch is a 6 puck sprung clutch. ACT 6 puck would have destroyed the tranny by now</TD></TR></TABLE>
Exactly...what the **** do you need a 6 puck clutch on a street car for? I really dont understand people...
Re: (BauleyCivic)
I want to change all the bearings in the tranny. Would you know how many they are in there. I want to go OEM so do you know how much they go for?
C-West Civic
09-10-2013 04:58 AM
SSBlueDC2
10-24-2003 02:25 PM
