starting problem W/ DPFI
Old Mar 10, 2009 | 06:01 AM
mass-hatch's Avatar
Default starting problem W/ DPFI
Ok every time i fill up my gas tank ,my car wont start right up .i would have to cycle the key a bunch of times then it will start....has anybody seen this before and i get a code 16 for injectors .i did the test for the code and its all ok inter-mitten problem....any help is good help thx berto
Old Mar 10, 2009 | 06:23 AM
IntegraLova's Avatar
Default Re: starting problem W/ DPFI
When you take off your gas cap is there pressure released or nothing?
Old Mar 10, 2009 | 06:32 AM
exz0n-.-'s Avatar
code 16 = main relay.
Old Mar 10, 2009 | 07:34 AM
honda.lioness's Avatar
Check the main relay per http://www.tegger.com/hondafaq/start...html#mainrelay. This test costs nothing but maybe 10 minutes.
Other possibilities are a malfunctioning injector resistor box and the injector wiring otherwise somehow becoming fouled. Did you use the shop manual's diagnostic procedure for checking on Code 16 and so the injector wiring?
Old Mar 10, 2009 | 07:40 AM
jagass's Avatar
Looks like your engine becomes cold so fast...
Old Mar 10, 2009 | 09:05 AM
mass-hatch's Avatar
some time's there is pressure and some time's there is none
i dont recall main relay a option on the test but when i have to cycle the key sometimes i dont here the click from the relay......
im going to try that relay test see what happens......thx
ExtraBlackRex
Oct 28, 2010 05:18 PM
juanchoenuncrx
11
Apr 4, 2008 07:38 AM
allm0torGSR
Apr 30, 2004 05:10 PM
pokemon
Jul 26, 2003 09:24 AM
typegsr
Apr 30, 2003 05:01 PM
