gsr internals in ls block???
Old Mar 9, 2009 | 10:08 PM
theme's Avatar
Default gsr internals in ls block???
is it possibly to bolt in a gsr crank rods and pistons into a ls b18b1 block? I dont wanna go vtec as i have a ls top end that I like. Just wanna know if this will work simply cause I bought a crank aluminum rods and forged pistons for what i was told was a ls but they are for a gsr.. anyway, thanks people..
Old Mar 9, 2009 | 10:26 PM
92cxturbo's Avatar
Default Re: gsr internals in ls block???
yes it works but your losing displacement, and compression will be slightly more
Old Mar 9, 2009 | 10:43 PM
95skunkedgsr's Avatar
wat brand pistons, rods ,and crank and wat comp i might be intereasted in buying it off u
Old Mar 10, 2009 | 06:12 AM
theme's Avatar
stock knifedged crank, aluminum rods dont know the brand and cp pistons
Old Mar 10, 2009 | 06:14 AM
theme's Avatar
Im not sure how i'd lose displacement?? a gsr is a 1.8ltr, after i got this and found out i was like ok this will rev better if it'll work... I have a professionally ported ls head with crower valvetrain and crower 404s, so i wanna stick with a ls block plus I dont wanna change blocks incase I ever drive the car to cali etc I want the numbers to match.
Old Mar 10, 2009 | 06:32 AM
dyingwish's Avatar
The stroke is different between the GSR and the LS...less stroke = less displacement.
Old Mar 10, 2009 | 06:37 AM
hmoobhero's Avatar
gsr crankshaft has a shorter stroke than ls crankshaft. thats why ls has alil more torque than gsr. are your piston stock bore size? also, the gsr rods are alil longer than the ls rods so there mite be some piston/valve clearance issue. do some research, theres a thread that talked bout this. gl.
Old Mar 10, 2009 | 08:12 AM
b20c's Avatar
u can do it ls crank, rods in a gsr/r is a 2mm stroker setup. So it would be a
de-stroked ls might b ok wit 404s. i dunno
Old Mar 10, 2009 | 09:22 PM
what comp pistons .. any intreast in sellin ??
Old Mar 11, 2009 | 10:03 AM
theme's Avatar
maybe, there 9.7:1-10.2:1 I dont know why they advertise different compression for them but they what the part number comes back as. I think it depends on what head is the only thing I can think of..
Old Mar 11, 2009 | 04:14 PM
o0 na i was lookin for the 11.5 12.1 range
Old Mar 11, 2009 | 05:06 PM
theme's Avatar
its cool, i was gonna spray a staged big shot.. I paid 500 for it all in perfect shape..
1991islsv
Nov 21, 2008 07:25 PM
Project_EK
Jun 5, 2008 09:17 PM
patrick4588
Oct 18, 2007 12:33 PM
tnsxsear1
Feb 8, 2004 09:59 PM
B18C1_T
Nov 19, 2002 01:20 PM
