vtec question
Old Aug 12, 2002 | 08:29 AM
rock47's Avatar
Default vtec question
I have a 89si motor crx I did the mini-me swap thats the 92-95 delsol or civic head some people say you have to move the oil control jet from the block because otherwise there will be to much presere in the vtec head and it will not ingauge.The guy who did the swap for me did not do that but he did wire the vtec up through a shift light and there is power to the vtec seliniod.But i cant tell if its working. Thanks Rocky
Old Aug 12, 2002 | 08:31 AM
Spade's Avatar
Default Re: vtec question (rock47)
Dyno.
Old Aug 14, 2002 | 03:41 PM
rock47's Avatar
Default Re: vtec question (Spade)
dyno? You dont understand my question then. I want to know if I have to remove the oil control jet on my block for vtech to engage. In that case I need to remove my head so my question is, Is it absolutely nessary to remove the oil control jet when doing a mini-me swap? If anyone has a real answer please respond.
Old Aug 16, 2002 | 07:23 PM
rock47's Avatar
ttt.... anyone?
Old Aug 16, 2002 | 11:50 PM
Mista Bone's Avatar
D Tranny Guru
yes you have to remove the oil control jet.
The VTEC head will have the jet already in it.
A little wood screw + vise grips works the fastest.
Old Aug 17, 2002 | 05:00 PM
rock47's Avatar
Default Re: vtec question (Mista Bone)
so basically now im beat. I need to remove the oil control jet so that means I have to tear down the head that just got put on? Anyone have any other suggestions? Can I do something so i dont have to remove the head????
Old Aug 17, 2002 | 08:45 PM
Mista Bone's Avatar
D Tranny Guru
no other choices if oil control jet was NOT removed.
Pop the head back off!
kk333
Dec 2, 2013 07:39 AM
twotone64
May 21, 2010 08:42 AM
chrisir19
Dec 19, 2003 07:19 PM
nissanpwrds14
Oct 20, 2003 06:42 PM
ViperRedCRX
Jul 31, 2003 12:10 AM
