Single Cam Vtec
Old Mar 9, 2009 | 07:37 PM
psychobear85's Avatar
Default Single Cam Vtec
So I Want To Go Single Cam Vtec Currently I have A 99 Honda Civic dx I Want to Drop A Single Cam Vtec From A 2000 Civic What Would I Need Besides The Engine I Got That Kinda Asking For A checklist Of Sort...Would I Need Need Axles,Tranny,ETC.......
Old Mar 9, 2009 | 07:38 PM
SadKorean34's Avatar
Default Re: Single Cam Vtech
Vtec*
Old Mar 9, 2009 | 07:42 PM
Sorry Computer Corrected My Spelling
Old Mar 9, 2009 | 08:15 PM
CivicSpoon's Avatar
You Will Need To Get The Correct ECU For The Engine You Are Getting. Then You'll Have To Do Some Wiring Changes. Everything Else From The Old Engine Will Work Fine With The New One. By The Way, When You Capitalize The First Letter Of Each Word Like This, It Makes It Harder To Read. It Is Also FREAKING ANNOYING!!!
Old Mar 9, 2009 | 08:18 PM
batallic's Avatar
search up "mini me" droppin a vtec head on the block
Old Mar 9, 2009 | 08:22 PM
92EGMINIME's Avatar
yeah i was gunna say just buy a vtec head and save a few bones for more mods
Old Mar 9, 2009 | 08:25 PM
Cool Thats What I Was thinking This Is my first Honda I Actully Get To Work On And Do Things That I Want To It
Old Mar 9, 2009 | 08:29 PM
batallic's Avatar
Some1 just told u to stop caps as first letter that **** is annoying and by an ex trans big difference
Old Mar 9, 2009 | 09:00 PM
1LowSol's Avatar
LOL don't worry about it man, I had to habbit to do that. I just broke myself of it.
Old Mar 9, 2009 | 09:14 PM
fastrxu's Avatar
Youre better off buying a whole d16y8 engine with tranny. If you buy the head you'll probably need to resurface it, all new gaskets, labor, timing issues, knock sensor,dizzy, and you'll have a granny tranny. Just buy the whole thing assembled with tranny and all.
Old Mar 9, 2009 | 09:20 PM
thats what i migth do sorry for the cap letters i was at work and every word there i have to start with capital letter, but i was just thinking of buying the whole swap,besides the motor,the tranny,ecu what else would i need,like axles,**** like that
Old Mar 9, 2009 | 09:37 PM
SOHC_civic_si's Avatar
That is a waste of money IMO. Hell a VTEC head swap is a waste of money in my opinion. But if you really want to and your D16Y7 is fine (doesn't burn oil or knock, etc.) you should just get a VTEC head with all the necessary parts you will need (VTEC ECU, VTEC solenoid etc.), and an EX transmission, nothing more.
Old Mar 9, 2009 | 11:06 PM
trustdestruction's Avatar
all you need is the ECU, and to wire up VTEC.
Old Mar 10, 2009 | 08:27 AM
fastrxu's Avatar
Like I partially said earlier you need to wire in vtec, and knock sensor, adjust timing because y7 and y8 are off by a tooth, change the ecu, new head and intake manifold gasket, wire the dizzy, change the iacv from 3 wire to 2 wire, ecu and dizzy from 99-2000 and all of this with no cel's or vtec wont engage therefore eliminating the purpose of the build. you can use the same tranny and axles but the si/ex tranny is shorter gears; axles are the same
Old Mar 10, 2009 | 08:28 AM
fastrxu's Avatar
Oh and resurface the head make sure it's not warped too bad and that valves are all good
Old Mar 10, 2009 | 05:41 PM
92EGMINIME's Avatar
or u can just cut a hole in the floor and go fred flintstone style
Old Mar 10, 2009 | 05:47 PM
shadohconspiracy's Avatar
the more i think about it, the more i find "mini-me" swaps pointless. unless the head was given to you for free, otherwise i will just leave the little single cam alone.
Old Mar 11, 2009 | 12:17 AM
92EGMINIME's Avatar
meh i bought my car with the swap so im good just a nice vtec starting point for boost
Floyd91
15
Apr 14, 2020 09:51 PM
MyLilHatch
Apr 10, 2006 11:58 AM
Threshld1
Jul 13, 2002 10:35 PM
allmotorEG-SI
Jun 4, 2002 11:47 AM
