IAC problem?
Old Mar 9, 2009 | 09:33 AM
2000turbosi's Avatar
Default IAC problem?
I've researched, thanks in advance for any help.
Car: 2000 Honda civic SI
Full turbo, wire tuck, 400whp, etc.
Having an issue with my idle. Started a month ago, picked my car up from getting re-dynoed. Had issues with cold weather, after being warmed up car ran fine...no issues. Started my car up today, will not hold any kind of an Idle, and completely shuts off. I have to rev the car to keep it alive... Any time the car is at an idle, it shuts off.
Checked so far: all vacuum lines, spark plugs, took off IAC and cleaned the screen etc...still does not fix the problem. In addition the fuel curve for the idle is fine that was set by the tuner, so the car is getting enough fuel at idle.
My question, should I just buy a brand new IAC valve?. Ive heard that these really don't go bad in some of the research that Ive done?
Thanks again for any help
Old Mar 9, 2009 | 09:54 AM
mouab18c1's Avatar
Default Re: IAC problem?
is there any CEL? makes no sense in replacing your IACV when you dont really know what the problem is..
Old Mar 9, 2009 | 12:00 PM
no cell at all...no check engine light, etc...
Old Mar 9, 2009 | 12:15 PM
If the IACV is bad, will it throw a CEL?...Also, my car is 9 years old, so how often do these usually work for?
thanks
Old Mar 9, 2009 | 12:41 PM
92cxturbo's Avatar
what program are you running? Are you running a wideband? how do you know the fuel is good?
edit: Also there is a setting for ect vs fuel/idle so if the fuel curve is fine at one temp it may not be good at alot colder temp.
Old Mar 9, 2009 | 01:20 PM
using hondata s100...the car was tuned when it was 20 degrees outside...it was 55 today and just kept shutting off...I had the tuner double check for the cold start fuel settings...just trying to see if I am forgetting anything...thanks
Old Mar 9, 2009 | 01:53 PM
92cxturbo's Avatar
I would get a wideband even if you aren't doing the tuning for situations like this and for peace of mind.
Old Mar 9, 2009 | 02:51 PM
thanks, maybe I will invest in a wideband...still trying to figure this problem out though...if the IACV is bad, it will throw the CEL correct?
thanks
Old Mar 9, 2009 | 03:40 PM
mouab18c1's Avatar
most likely it would....but it could be other things..i would check to see if your getting enough fuel...it sounds like when a car has a kill switch..with it off the car would start but get cut off due to the lack of fuel...
Old Mar 9, 2009 | 05:37 PM
ok thanks, Ill contact the tuner again....
Old Mar 11, 2009 | 12:28 PM
I've been trying to figure this out...I think I might have a bad IAT sensor?...Does anybody have any kind of similar experience as mine?...Weird thing is, there was no code thrown...I've been told that a bad IAT will not always throw a code?...
thanks for any help
Old Mar 12, 2009 | 06:31 PM
pimpchickpcfl's Avatar
LMK when you figure out the problem mine did the same thing! I replaced the feul pump, fuel filter, injectors, checks all vacum hose, clean pcv pipe (or whatever it is call), wires, cap, spark plugs) Its running now, but now it lags in low rmps
Old Mar 13, 2009 | 11:02 AM
I ordered a new IAT....I'll let you know...I'm going with the cheapest route possible first then from there prob. to a new IACV...
thanks
Old Mar 13, 2009 | 06:53 PM
where you order it and how much? i need to get one for my 99 civic si coupe
Old Mar 14, 2009 | 12:20 AM
go to majestic honda....and then go to the parts department
its like 40 shipped...why dont you wait till I know what it def. is?...so you dont have to waste money?
Old Mar 15, 2009 | 04:58 PM
vxhatched's Avatar
unplug the IAC and start the car and try to make the car idle with the idle screw on the throttle body and whatever fuel manage you are running, disable the IAC all together, it will idle much better.
Old Mar 16, 2009 | 04:36 AM
thanks, I ordered a new IAT a few days ago...Im just waiting for it to arrive....
Old Mar 23, 2009 | 01:32 PM
I got the new IAT in the mail, and installed it...It was the culprit to all my idling problem...It was $40 shipped brand new from majestic honda. So, this is a good place to start if you have idle problems like me (described above).
Pimpchickpcfl, I would give this a shot....Let me know how it works out...
MyEj1Broke
Jan 10, 2014 08:09 AM
Nisif
Nov 26, 2011 07:22 PM
PhatwhipsJDMkits
11
Apr 7, 2009 05:51 PM
Lmgrcivic
Apr 11, 2005 11:13 PM
Dr. Gonzo
Jan 12, 2004 03:53 PM
