92 civic won't start
Old Mar 9, 2009 | 07:31 AM
oj12757's Avatar
New User
Default 92 civic won't start
oj12757 wrote:
OK this is what i have done so far check main relay getting three clicks,fuel pump runs,starter engages,I have replaced coil,ignitor,ful pump,distributor housing,and iignition switch,replaced the emc with use one ,but when i connected the ground cable it gave off a little spark,don't know what cause this right i'm stuck don't know if it 's in the engine wiring debating if i should change the engine harness,thanks.
something else i notice was that the ground wires on the thermostat housing, i have 4,two blk,and 2 more,one of my blk one gose to the temp.switch.i've looked on other 92's they have 4 wires the same but all 4 and the temp switch has its on two ,is there something wrong with my harness?
SHOOT DEERE IT
43
Jul 21, 2014 04:39 AM
bmxerforlife58
Oct 20, 2013 11:09 AM
eg4doorGSR-T
38
May 22, 2013 11:41 AM
4dr2classy
15
Sep 15, 2012 10:28 AM
Cackophony
14
Jul 5, 2002 04:12 AM
