where can I get a wheel bearing pressed
Old Aug 12, 2002 | 05:32 AM
jweller's Avatar
Default where can I get a wheel bearing pressed
I've got to do the front wheel bearing on my 99 accord. I'm planning to do the work myself, but I don't have a press to put the new bearing into the hub, or get it out for that matter, but a hammer should work for that part, since I don't really care about the condition of the old part. does anyone know where I can get that done at? I don't want to go to the dealer, cause i know they will ***-rape me in the wallet, but I guess I will if I have to. does somewhere like auto zone do stuff like that.
or is there a reasonably priced tool I can buy? I'd do that if the tool wasnt too expensive. I've rented tools from auto zone before, but I don't think they have something like this.
Old Aug 12, 2002 | 05:39 AM
4doorH22's Avatar
Default Re: where can I get a wheel bearing pressed (jweller)
I took my knuckles to a local shop and had them press out the old bearings and press in new bearings. Don't remember what they charged it probably was 1 hr labor or 60 bucks. Make sure you bring in the bearing bolts so they can properly line up the new bearings.
Old Aug 12, 2002 | 06:52 AM
Gennady's Avatar
New User
Any local privately owned shop should have a press, and should be able to do this if you just bring them the assembly in 5 minutes. Should charge you $10-$20.
Old Aug 12, 2002 | 09:19 AM
Charlie Moua's Avatar
damn it seems like alot of accord are having bad bearing problem these days>
Old Aug 12, 2002 | 09:44 AM
bmm89's Avatar
Default Re: where can I get a wheel bearing pressed (Charlie)
A tip on those bearings... get the jdm hub and bearings already assembled, cost a bit more but well worth it. I got mine from manhonda but you have to call, the part number is different.
Old Aug 12, 2002 | 03:49 PM
TypeSH's Avatar
Default Re: where can I get a wheel bearing pressed (bmm89)
whats the advantage of the jdm hub/bearings
Old Aug 12, 2002 | 03:53 PM
jweller's Avatar
what makes the jdm hub and bearings better? this is on a 99, so the car isn't exactly the same as the USDM
Old Aug 12, 2002 | 06:31 PM
bmm89's Avatar
The quality is just so much better, i can say for certain that when comparing the two(both new) the jdm spun more smoothly, and the castings were much much better. Quality of finish and i believe bearings are most likely of higher quality and tolerances. Stocks were US, this is a 97 accord, built in marysville, OH. I will find the boxes for the honda part numbers. I also have a good drivers side bearing. I replaced both just in case, even though only right side was bad.
Old Aug 12, 2002 | 09:40 PM
TypeSH's Avatar
yea can you find the part #'s? I own a 94 so they should use the same bearings as your 97.
Old Aug 13, 2002 | 04:53 AM
4doorH22's Avatar
Default Re: where can I get a wheel bearing pressed (Wont be beat)
Yup, uh-huh, and then another $40 to pull the inner race of each wheel bearing off of each $170 hub.
Old Aug 15, 2002 | 08:08 AM
bmm89's Avatar
Default Re: where can I get a wheel bearing pressed (4doorH22)
Honda Part Number: 44600-SM4-020
This is for the "Made in Japan" part.
RacerTim
Sep 10, 2010 05:44 PM
bsmith100
Apr 12, 2010 08:05 AM
petergriffen
Aug 11, 2006 08:44 PM
ViZ
Feb 11, 2005 07:52 PM
buzlink
Jul 18, 2002 06:44 PM
