How to ensure I have a d16y5 head on my car
Old Mar 8, 2009 | 06:47 PM
85_305's Avatar
Default How to ensure I have a d16y5 head on my car
If you've been following my threads, it turns out somebody tried converting my HX to an EX.. they put in a p2p, an ex y8 intake mani, header, and possibly head. I'm hoping they didn't touch the head, but how can I be sure?
Thanks all,
Matt
Old Mar 9, 2009 | 05:17 AM
85_305's Avatar
Default Re: How to ensure I have a d16y5 head on my car
To The Topzors
Old Mar 9, 2009 | 08:21 AM
fastrxu's Avatar
The im is the same for hx and ex I'll check the head stamp and post it
Old Mar 9, 2009 | 08:26 AM
85_305's Avatar
I'm asking how to tell if my head is still a Y5 head... but no, ex and hx intakes are different. EX heads dont have EGR, HX do.
Where is the head stamp located?
Old Mar 9, 2009 | 02:01 PM
94EG8's Avatar
Seagull Management
The head stamp at least on B-series engines is above the exhaust ports, the only problem is it wont really help you much, the head code for both the Y5 and the Y8 is P2J. The bare head is the same, the cam and rockers are different though. Remove the valve cover and take a look, if you have roller rockers you've got the correct head.
Old Mar 9, 2009 | 02:05 PM
85_305's Avatar
Is there a way I can tell by peering down the oil filler? It sure looks like roller rockers from up here!
Old Mar 9, 2009 | 02:06 PM
speedooo's Avatar
Pop the valve cover off and see if it has roller rocker arms
Old Mar 9, 2009 | 02:10 PM
94EG8's Avatar
Seagull Management
Honestly I've never really looked. It only takes about 10 minutes to get that cover off though.
Old Mar 9, 2009 | 02:17 PM
85_305's Avatar
Will I have to replace the valve cover gasket? I'm scroungy as **** when it comes to doing things that appear unnecessary :p
Old Mar 9, 2009 | 02:29 PM
94EG8's Avatar
Seagull Management
Its actually a rubber seal, i've reused tons of them without any issues (obviously if its become hard and brittle its likely that it will begin to leak, but in that case it was due for replacement anyway.
Old Mar 10, 2009 | 04:34 AM
85_305's Avatar
oh ok.. I'll probably do that this weekend then. Thank bro!
jr_deleon
Aug 2, 2009 05:43 PM
codyb13
Sep 19, 2005 09:17 AM
black6gen
May 25, 2005 10:10 PM
civicnar
18
Jan 15, 2004 07:36 PM
Spade
Nov 21, 2002 01:03 PM
