cylinder head question
Old Aug 12, 2002 | 02:42 AM
Cashflo's Avatar
Default cylinder head question
how can you tell if your head is warped? also ive got all this carbon build up on my pistons. is it safe to use brake cleaner to clean pistons?
Old Aug 12, 2002 | 04:01 AM
EE_Chris's Avatar
Default Re: cylinder head question (eghead)
Brank Cleaner is fine for your pistons, then perhaps a light coat of WD-40.
As for your head, you have to use a precision straight edge and feeler gauges.
Old Aug 12, 2002 | 04:14 AM
Cashflo's Avatar
Default Re: cylinder head question (EE_Chris)
brake cleaner went into the coolant wells. does that mean i have to flush my engine. Or should i run the car like that?
Old Aug 12, 2002 | 07:13 PM
BreakStuff's Avatar
New User
you'll want to flush the system.. if the brake cleaner cleans off carbon deposits, then just imagine what it will do for your cooling system gaskets and seals...
Old Aug 12, 2002 | 08:26 PM
kinesistech's Avatar
Most straight edges are garunteed to.002" accuracy. The same as the specified allowable variance for a head. What a coincidence huh.
A little brake clean in your cooling system is fine. Dont worry about it.
Old Aug 12, 2002 | 11:11 PM
mugenracer's Avatar
Default Re: cylinder head question (kinesistech)
what makes you think your head is warped? did your engine over heat at any stage, or did you run low on oil?
LSVTECEF91
Dec 26, 2010 04:55 PM
jthm
Jan 31, 2007 09:18 AM
ZXRider
Dec 10, 2006 03:13 PM
vtecmike1
Apr 28, 2004 08:36 PM
showtymers619
Apr 12, 2004 07:10 PM
