HELPPPP!!! B series with EK engine harness wont start
Old Mar 8, 2009 | 02:01 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default HELPPPP!!! B series with EK engine harness wont start
i got a 99 LS motor swapped into my 99 civic
my old engine harness was messed up so i switched it out with a 99-00 civic si harness and i'm not sure if my distributor plug from my engine harness are pinned correctly (before the shop soldered the SOHC plug on the dizzy)
can u guys help me out with a diagram for this?
to clarify i need from 99 civic ex distributor pins to 99 integra plug
also, i have a obd2b to obd1 jumper and a chipped p28, with a stock map for a LS..
everything worked fine before i swapped the engine harness, no it's not sparking
the only things i left unplugged were the CPS, and o2 sensor.. will that disable me to have my car spark?
i'm throwing a code for Ignition Output Signal
can anyone help me out pleaseeeeeeeeee
Old Mar 8, 2009 | 02:23 PM
Default Re: HELPPPP!!! B series with EK engine harness wont start
Old Mar 8, 2009 | 02:40 PM
ahhhhhh
Old Mar 8, 2009 | 04:13 PM
FlatBlkEk's Avatar
the crank positioning sensor needs to be operative for your vehicle to spark
dnxracer
Aug 27, 2017 02:12 PM
creepy116
Mar 8, 2008 12:30 PM
RotiEatter
Jan 11, 2005 11:46 AM
honda eg9
Dec 6, 2004 02:54 AM
lsvtec101
Apr 16, 2004 03:15 PM
