turbo d16a6
Old Mar 7, 2009 | 09:46 PM
classdork987654's Avatar
Default turbo d16a6
will the afc hack work on the d16a6 runnin under 12 pounds of boost? i cant seem to find/understand any of the obd0 fuel manegment systems for runnin a turbo. what is an easy/simple way to run my turbo so i wont break down?
Old Mar 7, 2009 | 11:56 PM
jdmed3's Avatar
Default Re: turbo d16a6
you asking like fuel rail and injectors? use the dsm 250cc?? injectors and just pick up a aem fuel rail for better throttle response
Old Mar 8, 2009 | 10:53 AM
well i was going with bigger injectors too. but i just cant figure out the managment, there seems to be so many different types out there i just want something simple for now and to stay obd0 hopefully. just untill i learn how to burn chips or whatever the other programs require lol.
Old Mar 8, 2009 | 04:33 PM
what is the simplest way to run my t 25 at 12 pounds or less? more likely around 8-10 is my goal since its just to have a lil fun with but mainly get me to work.
Old Mar 8, 2009 | 04:47 PM
Blk_EJ1's Avatar
I say 10lbs and take it to speedfactory in tacoma....they'll take real good care of you.
Old Mar 8, 2009 | 04:50 PM
what kinda managment would they use? or you saying with the afc hack installed and have them tune it? i wanna take my car there eventually anyways ive heard good stuff about them.
Old Mar 8, 2009 | 06:26 PM
LoSt is BlaCk's Avatar
the forced induction forum.
DO NOT attempt the 250 injector suggestion...
you could also look into running an FMU (old tech, but a simple addition)
Old Mar 8, 2009 | 06:45 PM
fmu fuel managment unit? lol newbish. i posted a similar question with no response, a lil bit ago. is the afc hack a fmu? i have heard good things about it and heard that it sucks on hondas, im just trying to get my hatch in the 13 second area. lol
Old Mar 8, 2009 | 10:00 PM
well after searching around it looks like the vafc ahck is not really a popular system used. can the a6 be converted to obd1 for more options?
Old Mar 9, 2009 | 08:50 AM
4drEF's Avatar
Keyboard Humorist
"20lbs" and "10lbs" mean absolutely nothing since you didn't say what turbo you are using. 10lbs on a tiny turbo is less efficient than a larger turbo. This will yield different horsepower.
You can't select injectors, pistons, rods, or anything else based on psi. without knowing the turbo and motor specifics.
What hp are you shooting for?
THAT'S what you need to select parts.
Old Mar 9, 2009 | 12:05 PM
dephtone's Avatar
Personally for me it's less hassle to just buy a conversion harness and a obd1 dizzy. You will need a dizzy from a d15b7 and a conversion harness as well as a p05 or p06 ecu. The options that the Free Tuning software has is very open. Crome, Uberdata etc. Do it right the first time so you dont have to worry about blowing it up, I know the AFC Hack is still used but some people advise against it and why not when you have alot more options with the Free stuff.
There is no way to guess what kind of times you will run. I could say you would run a 13.9 but lord knows I dont know how you drive etc. So many factors are there traction, RT etc.
Old Mar 9, 2009 | 04:23 PM
Blk_EJ1's Avatar
I'm pretty sure that he said he was running a t25.....which is small and 10psi on a daily is coo....as far as what speedfactory uses I'm not sure....but I haven't seen anything bad come out of there and when I get my build going that is where I'm going to go.
Old Mar 9, 2009 | 07:38 PM
ya i am using my t25 off my saab hopefully, it was boostin 14 psi all day so i need to turn it down and as of now its just the stack bottom end until i can figure out the mangment issues then i plan on throwin in some vitaras and maybe some b series rods not sure whats good whats not yet. oh and stock head full rebuild. hp goal no more than 200, something realistic for a dd, maybe around 150 to 170.
ya i am def takin my time on this build lol started last spring. but the motor is done now im just deciding whih path she will take in life. (na or booooost)
Old Mar 9, 2009 | 10:05 PM
4drEF's Avatar
Keyboard Humorist
Yeah, just saw that T25 later in the post. Wasn't sure which it was though - T25-2B is a bit different than a regular T25.
You should be able to do the 180~200 no problem with stock rods and pistons. Putting vitaras and some other rods (might as well get a Z6 head too and convert to OBD1 too!) will in there will drop your compression and then you will probably want to get rid of the T25. At that point start looking into a turbo that can take you into the 300 and beyond numbers.
T25 is pretty small, spools up fast, but doesn't offer much of a topend. I think I have seen 2B's running about 14 psi and putting down about 24hp. with 10psi I think you should be right around your target numbers.
crxrider07
Sep 26, 2008 11:32 AM
VTteg
May 7, 2006 06:19 AM
menappi
Jul 9, 2005 03:36 PM
TuningOptions
Sep 1, 2004 12:43 PM
Hayasa15
Jan 28, 2002 07:24 PM
