need help asap with d16
Old Mar 7, 2009 | 09:31 PM
suspek808's Avatar
Default need help asap with d16
i got a 95 sohc v, just did oil change and now the car blows white smoke out the exhaust.... why is it doing that????? any info would be great... my friend changed oil with 5w30 full synthetic..... could this have been the culprit?????
suspek808's Avatar
Default Re: need help asap with d16
oh yeah, wasnt doing this prior to oil change.....
Old Mar 7, 2009 | 09:57 PM
suspek808's Avatar
damn, nobody?????
Old Mar 7, 2009 | 09:59 PM
Megalomaniac's Avatar
White smoke is burning coolant, this means a leaking head gasket.
Old Mar 7, 2009 | 10:07 PM
Former User's Avatar
Is the smoke actually bluish? if so, you are burning oil.
Old Mar 7, 2009 | 11:39 PM
trustdestruction's Avatar
I suspect that the smoke isn't actually white, and the synthetic oil is seeping past your valve seals and burning a little. Try using some Lucas Synthetic Oil Stabilizer (make sure to get synthetic, and make sure to drain a little oil so that you can put it in, otherwise you will have too much oil)
Old Mar 8, 2009 | 12:30 AM
suspek808's Avatar
thank u, will do so tomorrow.....
Old Mar 8, 2009 | 12:33 AM
Forgot to mention... it comes in a HUGE bottle. Don't use all of it. Follow the instructions.
Oil drain/refill capacity is like 3.5 quarts. The combination of the Lucas stuff and the Oil should not exceed the max line on your oil dipstick.
Loverice
Jul 18, 2014 11:47 AM
nengx07
44
Feb 6, 2009 09:29 PM
chickenandpickles
16
Sep 11, 2005 01:29 PM
vmm
May 19, 2005 11:54 AM
intekragsr
Sep 25, 2002 03:35 PM
