Anyone try these traction bars?
Old Mar 7, 2009 | 06:20 PM
sirtef9's Avatar
Default Anyone try these traction bars?
http://cgi.ebay.com/ebaymotors/_Car-...ht_2648wt_1140
Just wondering here if I would be wasting my money or not? Any first hand exp.?
thanks.
Old Mar 7, 2009 | 06:55 PM
sirtef9's Avatar
Default Re: Anyone try these traction bars?
bump before I buy!
Old Mar 7, 2009 | 07:16 PM
Ldo's Avatar
Ldo
Just my opinion, but it doesn't look very solid. I can't figure out how that will be bolted to the car. Are those thin metal pieces at the ends supposed to stiffen your chassis? Doesn't look like there is any good spot for jacking up the car either.
I would save up and buy a real one from other proven manufacturers.
Old Mar 7, 2009 | 07:19 PM
sirtef9's Avatar
I wanna trust me, but If anyone had good exp from these id go with them, not sure how they bolt up and they convienetly have no instructions
Old Mar 7, 2009 | 07:39 PM
SIred91's Avatar
Rainman
They bolt up to the tow hook bolt holes......LOOK at it.....
It's the cheap chinese made version of the old etd bar.....it will 'work' if you keep a
welder around.
Old Mar 7, 2009 | 07:40 PM
sirtef9's Avatar
What's bound to break on it first or most then?
Old Mar 7, 2009 | 07:44 PM
ZC DOHC CRX's Avatar
you really shouldn't cheap out with a part the is pretty crucial to the cars suspension.
Old Mar 7, 2009 | 07:47 PM
sirtef9's Avatar
Ya I hear ya, but I've seen some ebay products hold up to any other brand. Thanks for the feedback like I said i wanna see some personal exp. with these. I'll end up getting something better but was curious how good they were or werent.
Old Mar 8, 2009 | 11:23 AM
ef jay's Avatar
I have the ETD racing traction bar and I had to modify it so it would work. This style of bar only bolts up where the tow hooks go. It's a bad design because the bar will move back and forth no matter how tight the bolts are. The only way to keep the bar from moving would be to have it bolt up from the bottom like the original cross member did. I made mine work by welding plates to the sides that will bolt up from the bottom. I have not broke anything and I have 10,000 miles on it so far. I have used only street tires and no slicks. I will post a picture later when I get home. Hope this helps.
Old Mar 8, 2009 | 12:45 PM
gearhead16's Avatar
trust me dont go cheap on a traction bar that one will probly break if not it will bend
Old Mar 8, 2009 | 12:46 PM
gearhead16's Avatar
get a esp bar its a hell of alot strong and better and it bolts at the tow hooks and one bottom bolt it doesnt move!
Old Mar 8, 2009 | 05:27 PM
Dark_Teg's Avatar
My ETD bar came with brackets that bolt where the stock crossmember went and then bolts to the traction bar. Maybe you have the old design but i dont see how mine could move.
Old Mar 8, 2009 | 09:00 PM
ef jay's Avatar
I know what you are talking about. The "new" design is the same as mine but they give you a small tab. I don't see how that small tab would make a difference. When you hit the brakes, the wheels pull the bar back with all of the weight of the car multiplied by the speed at which your car is traveling when you are stopping. That is a lot of force. I don't regret buying this bar but I would not buy an ETD bar for an ef ever again.
This bar can be made to work. This is what I did. It's not pretty but it works. In the last pic, you can see rust where the paint was rubbed off from when the traction bar was moving. Every time it moved it would pop loud, that's when I knew something was wrong. I would just save my money and buy a better bar. One more thing, this bar hangs pretty low so it would not be good for a dropped car. Hope this helps.
Old Mar 9, 2009 | 05:14 AM
Dark_Teg's Avatar
Yeah the bar does hang pretty low but my jdm 4 to 1 header is my lowest point. The bar could be greatly improved with the addition of shouldered bolts to minimize movement.
Welding / Fabrication
Feb 22, 2012 04:43 PM
DFW
18
Aug 24, 2006 12:05 PM
Lo-Buck EF
Jan 5, 2004 10:13 AM
Boostless97Lude
25
May 20, 2002 09:04 AM
Phat Corolla
Jan 3, 2002 07:35 AM
