Can I get some help with 2 codes? 99 DX
Old Mar 7, 2009 | 01:25 PM
Arthas's Avatar
Default Can I get some help with 2 codes? 99 DX
Hello!!!!
I have a 1999 D16Y7 5 speed and its currently giving me (2) codes.
One code came on after I installed the header. I think that getting the secondary o2 sensor spacer should solve it but im not too sure.
Anyways, here are the codes:
1) P0132 CKT HIGH VOLTAGE
2) P0505 IDLE CONTROL SYSTEM MALFUNCTION
I was looking on Identifix.com and many people said something about a Vacuum leak for P0505. How would I check for that?
I have a spare IACV off of a 00' HX.
Old Mar 8, 2009 | 05:15 PM
Arthas's Avatar
Default Re: Can I get some help with 2 codes? 99 DX
Its a beautiful Sunday evening here in Southern California.
Old Mar 8, 2009 | 05:31 PM
Former User's Avatar
If you clear the codes, do they both repeat after driving the car?
Did you disconnect a vacuum hose and forget to reconnect it?
P0132 indicates a problem with the primary O2 sensor. Did you forget to reconnect it or not connect it tightly? Did you damage the O2 sensor wires?
Old Mar 8, 2009 | 11:47 PM
Arthas's Avatar
I dont think I disconnected a vacuum hose. I havent messed with those.
As for the P0132, I put the primary o2 sensor on the runner of the header. Now its only measuring 1/4th the air because it was at the end of the header before. I extended the wires of the secondary o2 sensor though.
Old Mar 22, 2009 | 04:22 PM
Arthas's Avatar
Could that be making my car run rich?
Old Mar 22, 2009 | 04:23 PM
EFinawesomeman's Avatar
A faulty O2 will make your car run rich.
Old Mar 22, 2009 | 04:31 PM
Arthas's Avatar
Its shoooting black smoke :/
Old Mar 22, 2009 | 04:48 PM
Arthas's Avatar
Old Mar 22, 2009 | 05:26 PM
Yeah your o2 is faulty then.
Old Mar 23, 2009 | 09:42 AM
Yeah, focus on the primary O2 sensor. That's where the problem likely lies.
jss43
Mar 7, 2014 03:26 PM
HommeDeBois
15
Jul 16, 2011 02:56 PM
candymanjl
Oct 6, 2006 03:41 AM
longhair77
Jun 23, 2006 11:00 AM
PWRDbyHseries
Feb 22, 2006 04:53 PM
