Don't no know much about ecu
Old Mar 6, 2009 | 08:28 PM
Najdmitr307's Avatar
Default Don't no know much about ecu
I don't know anything about ecu and I found nothing in the search. Does the hondata s100 work with the jdm p73?
Old Mar 6, 2009 | 08:46 PM
mtber's Avatar
Default Re: Don't no know much about ecu
The jdm p73 is obd2.
Hondata only works with obd1 ecus.
Read hondata.com
Old Mar 7, 2009 | 03:42 PM
How do I get rid of the govnor and o2 sencor?
Old Mar 7, 2009 | 07:21 PM
xenocron's Avatar
With an OBD2 ECU, you dont.
Old Mar 7, 2009 | 07:33 PM
mtber's Avatar
The obd2 ecu is not compatible with Hondata, Crome, eCtune, Neptune or any of the ecu chipping products on the market. You should use an ecu jumper (plug & play) & an obd1 chipped ecu.
Old Mar 8, 2009 | 08:44 AM
zuptidi's Avatar
Mtber is right, you have to get an obd1 ecu.
Old Mar 9, 2009 | 05:00 PM
What ecu and program do you suggust I have jdm b18c 99 spec r going for all motor
Old Mar 9, 2009 | 06:50 PM
THC07's Avatar
may i suggest buying an obd1 ecu from me, a jumper from ebay and youll be set.
I can put the correct basemap onto the ecu.
Once an obd1 ecu is chipped you can use it on almost any honda with the matching jumper and basemap (chip)
currently im selling a few chipped ecus for only 100$ untill i empty some inventory.
let me know if i can be of any help.
no need for hondata either.
Old Mar 10, 2009 | 09:56 AM
Relic1's Avatar
^^^ I'd suggest going with that deal. You're not going to find much cheaper or better than that.
and please for the love of god don't have the primary O2 sensor disabled.
It's there for the engine's protection. (imagine bare backing it at a brothel)
Old Mar 10, 2009 | 01:29 PM
What ecu are are you selling and what's basmaps?
No the o2 in the cat. I have the jdm test pipe.
Old Mar 10, 2009 | 03:18 PM
THC07's Avatar
p06 converted to a run vtec.
Which ever basemap you would need. sounds like you would want an ITR basemap.
let me know soon. im only selling two more ecus at that price.
How goes Relic? long time no see!
Zfracing
Mar 20, 2017 01:41 PM
underdog_racer
Nov 11, 2007 08:52 PM
spotscivic
Jul 8, 2007 04:53 PM
dkrex001
Oct 25, 2006 02:09 PM
eater_eg6
Dec 12, 2005 12:54 AM
