Why are dual pistons better than one? sorry its such a stupid question.
Old Aug 11, 2002 | 09:38 PM
dvp95's Avatar
Default Why are dual pistons better than one? sorry its such a stupid question.
I was thinking about doing the v6/legen caliper upgrade, but what is the advantage of the legend caliper over the v6 one? Is the caliper bigger than the sedan model? Also, about the dual and single piston thing too. Sorry I dont know much about the braking system, also should I buy it used at the kunkyard or new?
Thanks
Old Aug 12, 2002 | 07:34 AM
TWG's Avatar
TWG
Default Re: Why are dual pistons better than one? sorry its such a stupid question. (dvp95)
Here's an analogy:
Try to pick something up with only 2 fingers...(your thumb and forefinger)
Then try to pick up the same object with 3 fingers...
then try to pick it up with 4 fingers...
I bet the amount of pressure you need to pick up the object with 4 fingers is less than the amount of pressure with 3 fingers... and I bet trying to pick up the object with 2 fingers takes the most pressure (effort)...
Does that help ?
Old Aug 12, 2002 | 07:43 AM
Gennady's Avatar
New User
Default Re: Why are dual pistons better than one? sorry its such a stupid question. (TWG)
The pads is pressed flatter against the rotor surface. The pad is a little bigger. The entire caliper is bigger allowing for a larger heat sink.
Old Aug 12, 2002 | 08:18 AM
dvp95's Avatar
Default Re: Why are dual pistons better than one? sorry its such a stupid question. (Wont be beat)
Thanks guys! So is the reason for the Legend dual piston upgrade, the slightly larger pad for more area, or the fact that it is a dual piston caliper? Also, is it bad to do anything with the rear rotors?
Old Aug 12, 2002 | 08:23 AM
Brandon's Avatar
Life is Suffering
Here's the deal, the pads are the same, but are pressed flatter onto the rotor. Even though most people would tell you not to, you NEED to at least upgrade the rear pads. If not you will get severe understeer under braking. Except for that you should be fine.
Old Aug 12, 2002 | 08:31 AM
poison's Avatar
Here's an analogy:
Does that help ?
damn -- that was a very good metaphor
very nice
Old Aug 12, 2002 | 12:42 PM
dvp95's Avatar
Default Re: Why are dual pistons better than one? sorry its such a stupid question. (F22turbo)
I heard it was bad to upgrade the back rotors to make them larger, can you tell me why that is? Thanks again
Old Aug 12, 2002 | 02:27 PM
dvp95's Avatar
Where can I get a new set of the legend calipers? I checked the junkyards and they dont have it. Also, are AEM or brembo pads better?
Old Aug 12, 2002 | 02:31 PM
Brandon's Avatar
Life is Suffering
I personally recommend the AEM's, because they perform well and don't dust as much as other pads.
Charlie Moua
Suspension & Brakes
Oct 13, 2009 07:33 PM
4DALOOKS92
Aug 25, 2009 06:13 PM
dropped like its hot
Feb 28, 2006 06:33 PM
SKDRCR
Jan 18, 2004 05:18 PM
KMaxwell
Dec 25, 2003 08:49 AM
