How to install head unit?
Old Mar 5, 2009 | 09:43 PM
user 93082343's Avatar
Default How to install head unit?
Ok, first of all, I am not an idiot. For the crx is there supposed to be a cage in the dash that the head unit screws to, or DIN Rails? Or am I supposed to use the cage that came with the head unit? If I am supposed to use the one that came with the head unit, how do I install it?
-John
Old Mar 5, 2009 | 11:24 PM
DCRB's Avatar
Default Re: How to install head unit?
like in every car, there is supposed to be a factory sized "din", din and a half, or double din mounting spot. you should be able to just slide you new deck with it's provided cage into the factory hole. but to help us all out can you post pix up of where your radio is supposed to go, so we can help you better?
Old Mar 5, 2009 | 11:35 PM
boostedefhatch's Avatar
mine doesn't have ****! i have to take it to a stereo place i have NO cage it just chills in their my eclipse did not either no cage yeeeee FTW
Old Mar 6, 2009 | 06:38 AM
jdm_Jim's Avatar
use the cage that comes with the deck. you have to bend the tabs on the outside of it to clip and hold it in the plastic radio spot < should have phillips head screws on each side. slide the deck out of the cage with those thin radio removal tools first.
Old Mar 8, 2009 | 06:28 PM
KARSON's Avatar
first get a honda conversion harness.
and take out dask and put in the cage.
Old Mar 8, 2009 | 06:42 PM
Thanks for not really answering my question, I did get it installed though. Much simpler then I had thought.
-John
Old Jul 26, 2010 | 04:36 PM
ycm3's Avatar
how did you get it installed? i'm having troubles currently trying to get my pioneer deck out of my ef. I just bought it and it didn't come with any keys to take out the cage
Old Jul 26, 2010 | 05:42 PM
Canadian_EF's Avatar
you don't use keys. there are small tabs you bend to take it out
Old Jul 30, 2010 | 04:46 PM
PnoyJeff's Avatar
if u dont have any keys for the cage, probably just gonna need to get something skinny to stick in there and move the holding tabs off the deck..or just pry the bitch out
h22dx
Apr 12, 2012 01:37 PM
sdmark24
Acura TL, RL & ZDX
Jan 9, 2007 07:40 AM
PatrickGSR94
Audio / Security / Video
12
Aug 30, 2006 08:41 AM
B18EG6
Dec 19, 2005 04:15 PM
