Does anyone install Pioneer AVIC-F90BT?
Guys,
Has any of you installed Pioneer AVIC-F90BT, AVIC-F900BT or AVIC-F700BT in-dash all in one navigation system? If yes, please respond, I have couple of small questions.
Thanks in advance,
Ruben.
Thanks in advance,
Ruben.
I just tap into the wire using a t-tap. It all depends on the vehicle, where i hook it up at. I work at a car audio shop so thats why i say that. if you tell me year,make and model i can tell you were its at.
Speed sensor wire is blue/white and is located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console. There are 4 plugs total. The reverse wire is a green/black wire that can be found at the driver side of the fuse box or the harness that run's down the drivers side of the car. I wouldnt hook the radio to the e-brake, beacause it wont play a movie and the nav functions wont play while driving down the road. If you look up the brake by-pass for the radio on the internet it will tell you what to do. If you cant find it let me know and i will email it to.
i installed my F90bt into my current car which is an is300. the faceplate can't be removed, but just do a good job securing it is all i can really tell you. having tinted windows help, besides having an alarm obviously.
Guys,
I cant find the reverse wire in my fuse box. Please take a look:
https://honda-tech.com/forums/showthread.php?p=37721070
JadeGreenEF9
Sep 20, 2006 03:03 PM
