obd0-obd1 jumper question
Old Mar 4, 2009 | 04:48 PM
samhonda95's Avatar
Default obd0-obd1 jumper question
do you have to use a jumper for the dizzy and use a obd1 for doing this?
and if so why?
Old Mar 4, 2009 | 04:57 PM
mtber's Avatar
Default Re: obd0-obd1 jumper question
You must run an obd1 or obd2 distributor when using an obd1 engine computer.
Obd0 distributors will not properly function with obd1 engine computers.
Old Mar 4, 2009 | 05:55 PM
Blown90hatcH's Avatar
You don't have to run the distributor jumper, it just makes things easier. If you are using an OBD1 OEM computer, than yes you need an OBD1 or OBD2 distributor as the trigger wheel count is different from that of the pre-OBD distributor.
Old Mar 4, 2009 | 07:58 PM
samhonda95's Avatar
thanx guys it must be the car then.
i have a 91 teg and jumped it with the obd0-obd1 ecu jumper and a p75 ecu and a obd1 dizzy with the jumpers and it doesn't work.
Old Mar 6, 2009 | 07:58 PM
locash's Avatar
Define "doesnt work". You may just have a simple wiring problem.. Which ecu adapter are you using?
Old Mar 6, 2009 | 08:54 PM
mtber's Avatar
1. Check for malfunction indication codes.
2. Resolve all malfunction indication codes.
3. Check for fuel.
4. Check for spark.
Old Mar 9, 2009 | 05:47 PM
1fast4g63's Avatar
Sorry if I am hijacking this thread but I have a question about the OBD1 and OBD0 distributors. What's so different about them? I have swapped the CKP and CYP (cam angle sensor) wires accordingly from OBD0 to OBD1 on a 91 CRX with a D16Y8. The car runs and idles very low. When you drive the car, there's absolutely no power and the RPMS move very very slowly.
Take a look at this pictures....What prevents an OBD0 distributor properly running a VTEC engine with a P30 ECU (this is the computer I am using in the CRX)??
Old Mar 10, 2009 | 04:21 AM
Nothing in that picture. Go count the teeth of the wheel on both distributors and report back.
AzCRX
Apr 15, 2007 04:23 PM
91dxcrx
Jan 22, 2006 05:46 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
Civic
Jun 7, 2003 08:55 AM
