Cel code 4
ok guys i need help i had my car on boost for about a year now not much problems car is a 1999 honda civic 4 door it has a d16y7 i just dropped that motor to put a d16a jdm d16z6. Everything is done and car starts fine vtec is wired right but it will not rev over 3700 rpm. i get the cel code 4 on every computer i try (chipped obd1 p28, obd2b computer, and even on my phearable chipped p06 with hondata s100 vtec socketed) what is the problem and what can i do to "fix" "bypass" or get rid of this problem.........
THANK YOUCEK
THANK YOUCEK
Check your wiring from the distributor back to the ECU, if everything is good and you continuity from the distributor to the ECU the distributor is bad, replace distributor housing.
ya there are is a wire you relocate to another pin locoation. I dont know which one right off the top of my head but they have Pin readouts for it somewhre
xkrazyxjbrkerx75
19
May 18, 2010 04:11 PM
