d16y8 obd2-obd1 swap help
i recently swap my 96 civic hatch with a d16y8
(did a complete swap over, engine harness and etc)
I am using a obd2-obd1 conversion harness
and also running a stock p28
for some reasons my car idle at 1,500 and the all the lights are flickering
also the check engine light is on
some says that i need to change the dizzy. while other said i need to change the alter
so i am confuse. can someone please explain and clear things a little bit more as in what i still need or what i should do next
any help will be greatly appreciated
Before you start randomly changing parts you should pull whatever codes you have. There is a reason your cel is on and your answer may be right under your nose. ELD?
efn00b
Jun 12, 2011 09:28 PM
