d16y8 to ob1 conversion help
Old Feb 6, 2009 | 07:17 PM
king_pin's Avatar
Icon6 d16y8 to ob1 conversion help
hey i have just recently swap my EJ to a d16y8 and converted to a obd1
using a obd2-obd1 wire harness and i am also using a stock p28 ecu
for some reason my check engine light is on and the car seem like its darning alot of powers (the lights is flickering) the car also idle
any help would be appreciated
Old Feb 6, 2009 | 07:18 PM
king_pin's Avatar
Default Re: d16y8 to ob1 conversion help
help
Old Feb 6, 2009 | 07:19 PM
Unseen Racer's Avatar
from what i know of OBD conversions, you did it right.
OBD2-OBD1 wire harness and a p28.
what codes are you throwing?
Old Feb 6, 2009 | 07:20 PM
Originally Posted by king_pin
bump
WTF?!?!? bump after one minute?? ARE YOU ****ING STUPID OR WHAT?!?!?!?
YOU SHOULD BE BANNED FOR STUPIDITY IN THAT ALONE!
Old Feb 6, 2009 | 07:23 PM
king_pin's Avatar
oh my bad
i was just playing bout the bumping
you know how it is when no one is there to help
anyways
how do i check for the code
my ej doesn;t have the plug like the eg where you can check it
Old Feb 6, 2009 | 07:40 PM
ITS ONLY BEEN ONE MINUTE! you have to give it time for ppl to see, read, and reply.
and connect your OBD1 diagnostic reader to the OBD1 connection port. it should be on your driver side. under the leg panel
Old Feb 6, 2009 | 07:45 PM
king_pin's Avatar
i don't have a obd1 diagnostic reader, i only have a obd11. Is there another way, to do it like the eg?
Old Feb 6, 2009 | 07:52 PM
i believe there is a 2 pin connector by the ECU. or above the glove box. disconnect it and connect both with a paper clip.
your CEL will start blinking. and depending on the number of times it blinks and how it blinks(if it stays on long or a quick blink) it well tell you the code.
BUT i am not 100% sure of this 2pin location. i would search but the search is down
Old Feb 6, 2009 | 08:02 PM
king_pin's Avatar
i don;t belive the ej doesnt have the plugs like the eg
Old Feb 7, 2009 | 12:08 AM
honisoto's Avatar
yes they do have it
Old Feb 8, 2009 | 10:01 AM
king_pin's Avatar
can you show me wheres the plug is located at or tell me
cardinalredeg
11
Aug 17, 2010 06:07 PM
warrick
Mar 27, 2009 04:01 AM
TEAM JDM-P
Oct 16, 2008 06:31 AM
94eg5squadMD
May 4, 2007 10:58 AM
gray_civic_coupe
Nov 4, 2005 02:20 PM
