Rear Camber kit went from negative to positve 0_____0
Old Mar 3, 2009 | 09:26 PM
Weifast's Avatar
Default Rear Camber kit went from negative to positve 0_____0
Hey guys,
something weird happened just now as I got back form school. I had my rear camber kit set at approximately negative 1 deg camber, but after a long day of driving from and to school, i notice after I parked my car in my garage, the rear right tire now has positve camber 0____0 WTF...all the other tires are okay and seem to have the proper camber at which I originally set it.
Does anything know what's going on? I tightened down the camber kit like I was suppose to, so I don't know what could be going on. THe bolts are tightened down and the washers that are suppose to lock in the length of the camber on the rear is tight as well too, is the threading getting loose already? Happned to anyone? I have a skunk2 kit, and i just barely installed the kit like a week ago.
Old Mar 3, 2009 | 11:23 PM
Weifast's Avatar
Default Re: Rear Camber kit went from negative to positve 0_____0
I'm gonna go ahead and bump this before bed and hopefully get an answer tom morning.
Old Mar 4, 2009 | 10:44 AM
Weifast's Avatar
nvm, had a chance to look at the rear camber kit this morning, the washer that locks in the rear camber kit came loose somehow. Either I didn't tighten as much as I thought, or I did tighten and all the vibration from the road and engine caused the washer to come loose...which in retrospect...all equates down to the fact I didn't tighten it down as much as i should -______________________- Eh problem solved.
Conclusion
Suspension & Brakes
24
Aug 28, 2008 05:13 PM
kseriesDC5
Sep 1, 2004 07:11 AM
SB97civic
Mar 11, 2004 11:09 PM
Hatch_00
Jan 11, 2003 10:15 PM
