someone help please :( OBD? Injectors
Old Mar 3, 2009 | 06:25 PM
vlc92189's Avatar
Default someone help please :( OBD? Injectors
well i need injectors to finish my car and i got some obd1 injectors from someone off here. problem is they dont clip together ( the new injectors ) into what i have now. there both obd1 but here are pictures.
the one with the 2 tabs is the new injectors
and the one with no tabs is the old.
can someone help identify please? thanks
Old Mar 3, 2009 | 07:38 PM
vlc92189's Avatar
Default Re: someone help please :( OBD? Injectors
anyone?
Old Mar 3, 2009 | 07:53 PM
delusionracer's Avatar
left is obd2, right is obd1.
Old Mar 3, 2009 | 08:18 PM
trustdestruction's Avatar
you're gonna need injector clips. you can get some from phearable.net
Old Mar 3, 2009 | 08:19 PM
vlc92189's Avatar
thanks man.. can any one else verify that? (not doubting you, just wanna know for sure before i text the guy for my refund)
Old Mar 3, 2009 | 08:22 PM
if you get injector clips you can make them work. or you could even hardwire them.
Old Mar 3, 2009 | 08:47 PM
vlc92189's Avatar
well where could i get injector clips? i really only have 2 days to work on the car
Old Mar 3, 2009 | 08:51 PM
Old Mar 3, 2009 | 08:52 PM
its not worth the hassle. dont take short cuts on your car. leave your harness the way it is and get the right injectors. what car and motor are these injectors for? if your looking for stock EG injectors i have a set i will give to you.
Old Mar 3, 2009 | 08:58 PM
using injector clips isn't a shortcut.
if that's a shortcut to you, then would you call using an ECU conversion harness to convert to OBD1 so you can tune a shortcut?
Old Mar 3, 2009 | 09:00 PM
vlc92189's Avatar
its a obd1 JDM B16 in a OBD2 car. i really ont have time to ship out and recieve parts in 2 days im pretty time limited. which this is the reason im so pissed.
can anyone else verify that the left picture is obd2 and the right is obd1?
Old Mar 3, 2009 | 09:06 PM
vlc92189's Avatar
and another question, can any OBD1 B series Injector work?
Old Mar 3, 2009 | 09:07 PM
they are. and to make sure i just went and looked at a set of OBD1 injectors i am storing in my closet (for now).
you could always hardwire them.
Old Mar 3, 2009 | 09:13 PM
vlc92189's Avatar
thanks my man.. im just gonna go to the junkyard because i dont want to hardwire anything. just gonna keep everything stock because i only need 2 of the injectors, 2 of mine are bad. i appreciate the help. do you know if all b series obd1 injectors are interchangeable meaning i can use some from ls or del sol?
Old Mar 3, 2009 | 09:15 PM
they're all interchangeable fitment wise, but i'm pretty sure that some of the B series engines have different cc injectors, and you don't want to mix and match cc's.
Old Mar 3, 2009 | 09:48 PM
vlc92189's Avatar
alright thanks man
Old Mar 4, 2009 | 06:33 AM
not all B series injectors are the same. obd1 and obd2 are different. so you have an obd1 wiring harness in your engine bay?
Old Mar 4, 2009 | 06:45 AM
thats a harness. you are talking about hacking and splicing. your idea is a shortcut to solving an issue. if that was the only solution to the problem then i would say slice away but since he has optionsi would go for doing it right.
Old Mar 4, 2009 | 09:23 AM
oh so you were talking about the hardwiring... i thought you were talking about the injector clips.
anyway, yea i'd have to agree, hardwiring them is definitely something i wouldn't do... but if he's pressed for time to the point where he doesn't have time to get new injectors or some injector clips like he made it seem, that's kinda what he's gonna have to.
Old Mar 4, 2009 | 11:33 AM
91blackEF's Avatar
i would say go to the junkyard thats probably going to be your best bet if your pressed for time
Old Mar 4, 2009 | 11:34 AM
91blackEF's Avatar
P.S. i wouldent go to the parts store and get the bosch ones all i hear are bad things with them idk how ive never had to use them so i havent experienced any problems first hand but but i figured i would pass it on to you.
Old Mar 6, 2009 | 12:06 PM
vlc92189's Avatar
i ended up going to the junkyard. 91 blacck ef im from bmore to,u go out on sundays?
Turbo_y8
Jan 20, 2006 09:19 PM
cygnusX1
Nov 15, 2004 07:42 PM
G U E C O
Jan 22, 2004 10:54 PM
SlamMan
Jun 13, 2003 04:41 PM
