Poor mans type r low low idle!!
Old Mar 3, 2009 | 05:10 PM
BULLYAHOLIC's Avatar
Default Poor mans type r low low idle!!
I have a 1991 da with sir2 jdm b16a head (pretty much stock) on a gsr freshly rebuilt block, bored to 81.50 ctr pistons, 315 supra injectors, chipped ecu. Arp head studs.not tuned.
Problem is the car is idling around 200-500 rpms. I mean it's all but knocking off. If you drive it whenever you shift it will knock off. You must keep fluttering the gas pedal. It is also blowing a decent amount of white smoke!
I used a 81.00mm head gasket. Im thinking maybe head gasket. Any help would be very appreciated.
Old Mar 4, 2009 | 05:08 AM
Default Re: Poor mans type r low low idle!!
help! lol!
Old Mar 4, 2009 | 08:43 AM
mouab18c1's Avatar
hg is not your problem...my gsr is bored .5 over and i use the oem HG....and i dont get what you mean by knocking off? you mean cutting off? check your timing
Old Mar 5, 2009 | 02:34 AM
yes the car is cutting off. im pretty sure its my timing. i've taken the belt off about 5 times and put it back on but its still outa time. im thinking i must be doing something wrong.
Old Mar 5, 2009 | 03:29 AM
92civicx's Avatar
when did this happen? all of a sudden ? how long u been driving it? and i'm pretty sure u were supposed to get 81.5mm headgasket - i think honda makes that size....
Old Mar 5, 2009 | 07:07 AM
mouab18c1's Avatar
well did you ever time your timing with a timing gun?
Old Mar 5, 2009 | 09:46 AM
Rtboy10's Avatar
I had the same problem besides the smoke on my turbo y8 but it happened because my car was running so rich that it would actually flood and cut out.
Old Mar 5, 2009 | 10:27 AM
mouab18c1's Avatar
which ecu are you running?
Cole LaFleur
Jul 11, 2014 09:04 AM
BULLYAHOLIC
60
Feb 6, 2011 06:38 PM
BULLYAHOLIC
Engine Management and Tuning
Mar 22, 2009 10:49 PM
trbob16a
Apr 25, 2003 06:56 AM
