b7 block a6 head
Old Mar 3, 2009 | 09:28 AM
ef-hatchcrap's Avatar
Default b7 block a6 head
trying to put a a6 head in a b7 block what timing belt to use?
Old Mar 3, 2009 | 10:07 AM
Default Re: b7 block a6 head
cmon people help
Old Mar 3, 2009 | 10:34 AM
Furyof4's Avatar
B7 and A6 both use the same head casting, so use the b7 belt.
Old Mar 3, 2009 | 10:49 AM
Marcos Barrios's Avatar
what are the gains from useing the a6 head
Old Mar 3, 2009 | 11:04 AM
4drEF's Avatar
Keyboard Humorist
None.
Unless the B7 head is trashed.
Or unless the A6 head has a different cam, but then it's easier to just change the cam and not the head.
Old Mar 3, 2009 | 11:05 AM
89s1's Avatar
you'll need a y8/y7 cam gear or the timing will be 5 drgrees off, and you'll want to use the b7 timing belt.
Old Mar 3, 2009 | 11:07 AM
89s1's Avatar
Originally Posted by 4drEF
None.
If you don't know, don't answer.
The a6 cam is more aggressive than the b7 cam, gains will be somewhat noticable especially if you mill the head for a wee bit more compression.
the a6 cam wakes up the d15b2 and d15b7 quite a bit.
Si trannys are also good mods for cheap acceleration gains.
Old Mar 3, 2009 | 11:52 AM
4drEF's Avatar
Keyboard Humorist
It's not that I don't know about the cam.
The HEAD is exactly the same, so I was trying to figure why somebody would swap out the entire head rather than just the cam.
Old Mar 3, 2009 | 05:50 PM
a6 block locked up on a buddy this morning had both heads hw wanted to use the a6 but it wouldnt work with y7/y8 pulley and b7 t-belt.
So we just used b7 block and head with a6 cam and y7/78 gear and that worked perfect owner said it felt like it did before
91 EF DX
May 24, 2013 07:34 PM
jddwls
Mar 22, 2010 02:25 AM
stevethefishguy
10
Aug 31, 2006 10:21 AM
Civichatch27
Sep 17, 2004 03:12 PM
biggpoppac
Sep 9, 2004 06:55 PM
