I have a question on rod bearing clearence.
Old Mar 3, 2009 | 06:53 AM
computer07's Avatar
Default I have a question on rod bearing clearence.
Hello i built a forced induction b18c1 motor for my integra, the motor is already in my car and i found out i got the rod bearing clearences a little too tight. Is there any additive i can put to help wear the bearings or anything i can do to fit this. I just dont have the time to pull the motor and redo this. thanks
Old Mar 3, 2009 | 07:28 AM
dyingwish's Avatar
Default Re: I have a question on rod bearing clearence.
Nope, you have to pull it and swap out the bearings. No getting around tight clearances.
The surface of the crank journals and the faces of the bearings never actually touch, they're separated my a film of oil.....so they don't wear in at all. What were your clearances and how did you measure them?
Old Mar 3, 2009 | 02:36 PM
red02s2k's Avatar
How do you know you have them to tight?????? And when did you find out?
Old Mar 3, 2009 | 02:50 PM
Jas9848's Avatar
didn't you measure the clearances before you put everything together?
Old Mar 3, 2009 | 08:21 PM
96bstdgsr's Avatar
you dont have to pull it out. i have rolled rod bearings in my gsr twice and its easy.
Old Mar 3, 2009 | 08:26 PM
Scott_Tucker's Avatar
What are the bearing clearances?
vteczone
Aug 6, 2008 10:51 AM
JaHnAbOi
12
Jun 22, 2006 11:00 PM
d16dcoe45
Aug 14, 2005 06:21 AM
d16dcoe45
Aug 12, 2005 10:57 AM
ensracer
Jul 6, 2004 03:29 PM
