Timing
I'm still on a stock engine, but I heard that changing the cam gear timing to 18 degrees will give the car a little more push. Would I get any detonation on stock compression?
Are there other non-bolt on modifications to the stock car to increase performance? Like I heard removing the intake resonator will free it up a little and things like removing PS pulleys.
Just kinda trying to keep her pure "the way God meant it to be." - Delinquent
00 NBP ITR 0941
00 NBP ITR 0941
The intake resonator removed has shown to actually lose hp.
no detonation for me with 18deg timing
18 is still within spec, so i wouldnt worry
i have never dynod my car so i cannot prove this, but i cut up my intake resonator and used the pieces to make my own CAI
and it feels like it improved things, but then again, i added a k&n 2820 at the same time, so who knows...
aet
aet
http://www.c-speedracing.com
look in the howto section, it describes how to advance ignition timing.
bascially, u short the service connector of the ecu, loosen up the distributor, and with the aid of a timing gun,
make your adjustments.
tighten distributor, unjump connector, and there ya go.
does not require any aftermarket parts.
aet
aet
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
ashb82
Engine Management and Tuning
Jun 15, 2011 08:08 AM
