Timing
Old Aug 11, 2002 | 01:54 PM
gary201147's Avatar
Default Timing
I'm still on a stock engine, but I heard that changing the cam gear timing to 18 degrees will give the car a little more push. Would I get any detonation on stock compression?
Are there other non-bolt on modifications to the stock car to increase performance? Like I heard removing the intake resonator will free it up a little and things like removing PS pulleys.
Just kinda trying to keep her pure "the way God meant it to be." - Delinquent
00 NBP ITR 0941
Old Aug 11, 2002 | 02:01 PM
zijiejijeijrkjk's Avatar
Default Re: Timing (gary201147)
The p/s belt removal make a few hp.
The intake resonator removed has shown to actually lose hp.
Old Aug 11, 2002 | 03:22 PM
Rob :190:'s Avatar
Default Re: Timing (scott_k)
free hp/tq: remove P/S belt, turn of A/C, 18 degree ignition timing, and weight reduction (backseat, spare, tool kit, etc)
Old Aug 11, 2002 | 03:37 PM
aet6's Avatar
Default Re: Timing ( Rob)
no detonation for me with 18deg timing
18 is still within spec, so i wouldnt worry
i have never dynod my car so i cannot prove this, but i cut up my intake resonator and used the pieces to make my own CAI
and it feels like it improved things, but then again, i added a k&n 2820 at the same time, so who knows...
aet
Old Aug 11, 2002 | 04:11 PM
friedsqrl's Avatar
Default Re: Timing (aet6)
how do you advance the timing? do you not need aftermarket cam gears?
Old Aug 11, 2002 | 04:23 PM
aet6's Avatar
Default Re: Timing (friedsqrl)
http://www.c-speedracing.com
look in the howto section, it describes how to advance ignition timing.
bascially, u short the service connector of the ecu, loosen up the distributor, and with the aid of a timing gun,
make your adjustments.
tighten distributor, unjump connector, and there ya go.
does not require any aftermarket parts.
aet
Old Aug 12, 2002 | 05:02 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
jfyi, i dynoed 16 and 18 degrees, and 16 worked out best for me.
journeyquest
Aug 31, 2014 09:04 AM
ashb82
Engine Management and Tuning
Jun 15, 2011 08:08 AM
PROJECT 91
Jan 27, 2009 10:37 PM
quicksol95
18
Nov 18, 2003 04:25 PM
