Let's play another round of, NAME THAT BOLT!!!. Lots of PIX inside
Old Mar 2, 2009 | 04:34 PM
driveslow's Avatar
Default Let's play another round of, NAME THAT BOLT!!!. Lots of PIX inside
Car: 94 civic ex coupe d16z6 all stock
Ok, While I was trying to figure out why my tranny was leaking oil. I happened to notice that there was a bolt directly above the inside driver side axle. The bolt is immediately above where the axle sits or plugs into the transmission. I tried torquing down the bolt but it did not want to budge and I didnt want to force it down. I have added a bunch of pics for refrence.
My question, what is that bolt for and what does it do or hold.
Part 2 this bolt here for the tranny shifter I noticed moved when turning it with my fingers. Both bolt and nut moved together when turning with fingers. I couldnt turn it 360 degrees but just a couple centimeters in the lefty loosy direction. It appears like its the type of bolt that has to be tightened down by securing both the nut and bolt. Anyway is this normal that both the nut and bolt has play in it when turning it in the lefty loosy direction(a couple centimeters)?
Old Mar 2, 2009 | 05:03 PM
KillBot's Avatar
Default Re: Let's play another round of, NAME THAT BOLT!!!. Lots of PIX inside
Can't really tell what #1 is...maybe a mount bolt? If it is, then it could just spin because its not lined up.
#2...wow... Someone replaced the bitch pin with a bolt. I have never seen that before. The bolt looks bigger than a bitch pin, so whoever did it had to drill the linkage and the shaft going into the transmission.
Old Mar 2, 2009 | 05:10 PM
driveslow's Avatar
whoa, so for question number 2, the bolt with arrow is suppose to be a bitch pin? I am assuming this is not the technical term. I will look it up, but in the mean time, can you explain, is this a major no, no? The car shifts fine by the way. especially for a 13 year old car.
Old Mar 2, 2009 | 05:14 PM
KillBot's Avatar
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
^ #28 is the bitch pin. As for a no-no...I wouldn't do it. Someone just got lazy.
Old Mar 2, 2009 | 05:17 PM
98civdx's Avatar
Master Detailer
its called the bitch pin cause its a bitch to get out lol
amd yea its major if someone drilled it out for a bigger bolt the pin isnt going to fit back in.
but of it shifts fine i honestly wouldnt worry about it
Old Mar 2, 2009 | 05:21 PM
driveslow's Avatar
If a mechanic did it, i dont see why he would drill a bigger whole, when he could just use a nut and bolt that fits in the bitch pin hole. Either way, according to that part diagram, it looks functional with the bolt or bitch pin.
so that clears up question 2. Its fine that it spins a bit as long as it doesnt fall out. Now for question 1 yall...
Old Mar 2, 2009 | 05:32 PM
slimjimming6688's Avatar
it a bolt that bolts to the back of the tranny from the rear engine mount, #2 that bolt dont belong there, its called a role pin i think
Old Mar 2, 2009 | 05:34 PM
dohcdelsol's Avatar
just tighten up the bolt for the shift linkage and you will be fine
as far as number 1, its hard to tell but maybe part of the rear motor mount? what year civic and what motor is that? that will give us a little more help to figure it out.
Old Mar 2, 2009 | 05:36 PM
driveslow's Avatar
Dang it! I knew I was forgetting the most important thing. Its a 94 civic ex coupe d16z6 all stock.
Old Mar 2, 2009 | 05:38 PM
driveslow's Avatar
I tried tightening number 1 but its really tight and I didnt want to break something. When you say, rear motor mount, is it just for connecting the engine to the tranny?
Old Mar 2, 2009 | 05:39 PM
dohcdelsol's Avatar
http://www.hondaautomotiveparts.com/...++ENGINE+MOUNT
number 20 i believe
Old Mar 2, 2009 | 06:21 PM
driveslow's Avatar
doesnt look like number 20. but i am not certain. I do no that it doesnt spin easily. It feels as if the bolt is not lined up or has reached the end of the tranny hole as if the bolt is to long.
Old Mar 2, 2009 | 06:26 PM
KillBot's Avatar
I was thinking #20 at first...but its too far away from the driveshaft
Old Mar 2, 2009 | 06:40 PM
driveslow's Avatar
Do you guys think its dangerous to be driving around like this? I am sure there are other bolts in place for the same reason. Is this critical
Old Mar 2, 2009 | 07:04 PM
kpowerd 4g4d's Avatar
as for the bolt being the replacement for the bitch pin i have seen 2 that were done that way both of them i have seen when i worked at a shop and the cars came in for clutch jobs if the hole was drilled out you can put a bigger bitch pin in they sell them at bolt supply companies, if not you can hope that you order the right size off jegs or summit they have variety packs on there also as for one the bolt might be to long and it bottomed out so find the right bolt also
Old Mar 2, 2009 | 07:46 PM
popndrop's Avatar
Bolt #1 is probly hard to turn because the mount is on the car and weight of the motor/trans is on the bolt. try lifting the motor up a bit (w/ blocks) and then tightin and if that bolt is lose i would check all the others 17mm is correct size (preffer 1/2 ratchet)
Bolt #2 somehow the Roll/bitch pin fell out of my Ef and the shift linkage fell lol but i went to my local Napa and i got one that was a lil longer but nothing a grinder couldnt fix so if its drilled out then idk u can try and find one that size but i know stock ones are available
Old Mar 2, 2009 | 07:50 PM
Ya Digg's Avatar
I heard putting a bolt where the pin should be will make the shifter sloppy how is yours?
Old Mar 2, 2009 | 07:54 PM
popndrop's Avatar
i used a bolt Temporarily since my pin went missing it was very very very sloppy i went to go to 3rd gear and bout hit my passenger in the knee lol bolt was too small but it worked to get the car back to the garage
NOTE TO SELF the C clip that goes around the bitch pin if its there USE IT !!!! there is a reason its there
Old Mar 2, 2009 | 09:15 PM
Former User's Avatar
I am pretty sure that bolt #1 is actually one of the two bolt 27s in the diagram. Yeah, you''ll need to support the weight of the tranny with a jack to realign bolt #1 with its hole.
Old Mar 3, 2009 | 03:15 AM
driveslow's Avatar
shifting feels fine and exact. It's just loose rocking it left and right while in nuetral but I hear that is normal.
doom26464
Jun 18, 2008 07:10 PM
blkhatch92
Nov 20, 2005 01:58 PM
asubennett
Aug 21, 2003 05:14 PM
RCautoworks
Feb 16, 2003 11:16 PM
gumbybum
Jan 28, 2003 09:40 PM
