Car not starting...No gas?? 90 crx si
Old Mar 2, 2009 | 03:48 PM
-ThePhantom-'s Avatar
Default Car not starting...No gas?? 90 crx si
So today I go get in my car after class and it just turns over and seems like it is getting zero gas. I checked the spark from my distributer and thats all good, but i'm not getting any humming noise from the fuel pump and I loosened one of the 2 bolts on the fuel filter and got no gas squirtage.
So is my fuel pump out or what else could it be.
Pics: idk which one is actually my fuel pump or where its at.
Old Mar 2, 2009 | 05:24 PM
projectwheelspin's Avatar
Default Re: Car not starting...No gas?? 90 crx si
go the cheap route and change your fuel filter first there like 10bux if you are forsure not hearing the pump check all your fuses for the pump under the dash theres one for the pump could be one under the hood to not pos
Old Mar 2, 2009 | 05:25 PM
also you could have unhooked the return line check the other hose on the filter
Old Mar 2, 2009 | 06:26 PM
K well I am going to get a fuel filter...But would the humming come from the silver dome with the wire coming from it? also is the fuel pump under the silver dome in the middle?
Old Mar 2, 2009 | 07:01 PM
thats where the hummm will come from but you need to keep in mind it will only hmm for like 1 sec right when you turn the key on then stop
Old Mar 2, 2009 | 07:04 PM
exz0n-.-'s Avatar
check your main relay, that cause the fuel pump to not prime thus your car cranking and not starting
Old Mar 2, 2009 | 09:22 PM
Where is the main relay?
Tomorrow I am going to buy a new fuel pump and fuel filter so any suggestions on those?
Old Mar 3, 2009 | 04:00 AM
mastranios's Avatar
its under the dash on the divers side mounted just above the hood pop switch.
Old Mar 3, 2009 | 08:50 AM
K. Well I talked to a guy at my local import shop and he said 9 times out of 10 its just the main relay. Soooo are there anyways to check if my main relay is bad? Also is $65 reasonable for a main relay?
Old Mar 3, 2009 | 09:45 AM
junk yard just pocket them or if you want you can pay the dollar theyll charge you but 65 seems alittle high for a new one
Old Mar 3, 2009 | 09:56 AM
KILLAB17VTEC's Avatar
Genetically Gay
before u start taking the fuel pump apart.did u check for spark/gas?
Old Mar 3, 2009 | 10:21 AM
yes I have spark and my plugs are good..
I think I have narrowed it down to... Main relay, fuel filter or fuel pump.
Old Mar 3, 2009 | 10:34 AM
Genetically Gay
are u gettin fuel?if u are then its not the fuel pump.could be the starter.
Old Mar 3, 2009 | 11:44 AM
Damn bro... I know your trying to help and everything but I have said this stuff before.
Im NOT getting gas
I AM getting spark
But today I am going to buy new parts, so can someone please help me decide whether I need a main relay or puel pump.
Old Mar 4, 2009 | 02:04 PM
maim relay fixed it....
Thanks H-T
5honda
Sep 28, 2018 10:17 PM
Gabe87CRX
Classic Hondas
Apr 18, 2010 09:47 PM
pr3lude1992
Feb 18, 2009 06:30 PM
EKSedAndy
Nov 12, 2007 10:22 AM
Jockobo
Nov 16, 2002 11:09 AM
