will aftermarket exhaust tip pass smog
Old Mar 1, 2009 | 08:13 PM
fhukingviet's Avatar
Default will aftermarket exhaust tip pass smog
i bought a civic hatchback si 92 with about 94k miles on stock motor, only aftermarket things that came with it is a injen cold air intake with a carb number and some nastysounding aftermarket exhaust tip... will it have an effect any effect on the air that comes out compared to a stock exhaust pipe... thanks
Old Mar 1, 2009 | 08:17 PM
KillBot's Avatar
Default Re: will aftermarket exhaust tip pass smog
Tips don't normally sound nasty...are you sure the stock muffler is still on there, or the cat hasn't been replaced with a test pipe?
Old Mar 1, 2009 | 08:26 PM
oh the sound is like a deep sound like what aftermarket exhausts give, all the pipings seem to be stock and the stock muffler isnt there, cat seems to be there also
teamworxek9's Avatar
a tip wont make it fail but is the tip connected to a cheap canister style muffler? waht matters the most is the converter.
Old Mar 1, 2009 | 08:31 PM
93egSLEEPER's Avatar
youll pass, dont worry anymore. guys that are way more moded then what you have listed still pass.
Old Mar 1, 2009 | 08:38 PM
pictures uploaded, will a cold air intake matter at all also
Old Mar 1, 2009 | 08:40 PM
you just have an axle back it looks like... or they just used the stock pipe and did a ghetto weld to fit the muffler on there. either way you will pass and you intake has a carb# so your fine.
Old Mar 1, 2009 | 08:41 PM
thanks for the input, hopefully everything goes fine
Old Mar 1, 2009 | 09:09 PM
Damaged Goods's Avatar
Where the hell did you find a 92 si with 94k miles on it is what I'm wondering about...
Old Mar 1, 2009 | 09:13 PM
98civdx's Avatar
Master Detailer
^^^ x2
its no more then an axle back, your fine.
Old Mar 1, 2009 | 09:18 PM
san diego, 1992 clean title 3k$ ... included some carb legal airmass headers and other stuff... thought sunroof and brakelights were all broken but all i had to do was replace his fuses. paper work is kinda messy but im sure hes a good guy to help
Old Oct 28, 2010 | 12:54 AM
unknownally's Avatar
So did you pass?
Old Oct 28, 2010 | 04:27 AM
EJeff8's Avatar
Oh weak Bro. That looks like a GReddy EVO2 exhaust, minus the resonator. I run the Catback version. Way to hurt my feelings.
But that weld looks nothing like mine. I'm assuming someone gave them the muffler and they ghetto fabbed it, which would make sense on why it sucks on your car.
jeremy_dane
Mar 4, 2009 10:12 PM
cilvia
12
Mar 14, 2007 01:36 AM
vandersmissenc
May 11, 2006 07:45 PM
hmtcrxsir
Dec 15, 2005 06:08 AM
GsR HtCh
Aug 16, 2002 06:20 PM
