Remove passenger side airbag...
Old Mar 1, 2009 | 03:54 PM
jason_v2's Avatar
Default Remove passenger side airbag...
I have a 2000 DX hatch and I'm trying to remove the passenger side airbag and I'm a little stuck. I removed the 3 bolts and the harness plug after removing the glove compartment but still can't seem to pry out the airbag from the top.
Any suggestions...? Thanks!!
Old Mar 1, 2009 | 04:10 PM
teamworxek9's Avatar
Default Re: Remove passenger side airbag...
just pry on it from the bottom it will come out, i just had to do it.
Old Mar 1, 2009 | 04:37 PM
jason_v2's Avatar
whaet do you mean pry it from the bottom? should i be pulling it out through where the glove compartment used to be?
really frustrating.. the windshield isn't giving me much clearance to work with either..
Old Mar 1, 2009 | 08:00 PM
no, if you removed the three nuts you should be able to move the lower portion around a bit. i put a pry bar between the bar and the airbag and pryed it up, it popped out.
Goosse
12
Dec 11, 2012 02:36 PM
sk3ch
Sep 2, 2007 05:06 PM
clutchmaster2005
May 10, 2007 11:03 PM
jdm94accord
Sep 10, 2006 11:40 AM
GsRiNtEeGrA14
Feb 26, 2006 10:43 AM
