offset wheels
Old Mar 1, 2009 | 01:34 PM
88 EF Hatch's Avatar
Default offset wheels
So I know they sell offset wheels where when on car they are spaced out a bit. I have some offset konigs on my ef. Can you space out a rim or buy some type of spacer for normal rims so that it gives you an offset. Look? And if so what is it called.
Old Mar 1, 2009 | 02:11 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: offset wheels
You can "push wheels out" away from the car by getting spacers or by getting wheels with a lower positive offset number (or even negative offset). However, if they go out too much you can run into problems with clearance in the outside of the wheel wells, although you can add clearance by "rolling" (bending) your fender lip.
There are issues with spacers, too. Some spacers replace the lug nuts and others replace the hub lip for centering the wheel; others are just flat metal plates and because those lose the hub centering of the wheel, the wheels can be susceptible to vibration problems. Also, you need to have at least 6-7 full turns on the lug nuts; if the spacers push the wheels out beyond that point, you will need to replace the studs with extended ones, and get open-ended lug nuts.
All in all, there's a lot of stuff you need to do to make it work, just to achieve a certain "look". It's a whole lot easier to just find wheels that fit your car as is - with maybe a little bit less offset to push them out, but only a little, not enough to create any of these issues.
Old Mar 1, 2009 | 07:33 PM
ok sounds good thanks
Old Mar 1, 2009 | 07:39 PM
but one more question. Where can I buy these spacers? I dont want a huge offset. Just a bit.
Old Mar 1, 2009 | 09:44 PM
r.wright's Avatar
ebay or you can try h&r or look up kics project
Old Mar 2, 2009 | 02:14 PM
nsxtasy's Avatar
H-T Order of Merit
H&R's spacers are shown on their website here.
Old Mar 3, 2009 | 07:25 AM
Ok so My question is how do I go about deciding what size will look right? I see there are 20mm 40mm and 60mm. And what other brand wheel comes offset already like the konigs I have?
iHEARTMYCiViC
May 6, 2012 11:29 AM
Khmerican
May 14, 2008 03:25 PM
MI4$DC5
Apr 23, 2006 06:38 PM
DarkBB4
Jun 7, 2005 04:08 PM
JoeyBallzSI
Oct 20, 2003 03:04 PM
