VC sealing
Old Mar 1, 2009 | 06:55 AM
hondachris1994's Avatar
Default VC sealing
I have always dabbed some rtv/hondabond on the corners of the valve cover and have never had it leak. There was a guy that said all u have to do is oil the VC gasket and it wont leak from there. I have personally not put rtv in those corners and it ended up leaking. What are your guys input on that?
Old Mar 1, 2009 | 07:21 AM
Pothole987's Avatar
Default Re: VC sealing
Oiling the gasket? you oil it so it doesn't dry up and crack like on oil filters. i always put RTV on gaskets for valve covers and they never leak.
Old Mar 1, 2009 | 07:26 AM
The_Honda_Guy's Avatar
It specifically states in the shop manuals to put Hondabond HT on those 4 corners to prevent leaks. Also, if you had noticed when you removed the old valve cover gasket that there was Hondabond HT on those 4 areas. It is highly recommended that you Hondabond HT those areas when putting a new gasket on to prevent leaks.
Old Mar 1, 2009 | 07:30 AM
BryanM.'s Avatar
Resident Gearhead
Agreed, it seems like they always end up leaking eventually if no Hondabond or other RTV is used.
Old Mar 1, 2009 | 07:37 AM
Yep, I've had a lot of friends who removed their valve covers to paint them and put them back on with a new gasket but didn't Hondabond HT or RTV them and ended up with a leak out of those areas.
Do yourself a favor and stop at the dealership and pick up a tube of Hondabond HT. If you want to go cheaper, Permatex Gray is nearly the same, but not as good in my book.
Squigget
Feb 8, 2020 07:12 PM
rovafa2002
Jul 2, 2013 07:50 AM
touandcim
13
Dec 29, 2007 09:46 AM
seifer
Feb 22, 2005 06:01 AM
slowls
Jun 25, 2003 10:24 PM
