When to upgrade fuel pump????
Well, i have a type r intake ported, port n polish the head, biggest valves possible, retainers, springs, forged pistons, cams, complete head build
I would do it anyway...i'm pretty much in the same boat you are....i'm building a high compression n/a b16 as we speak and i upgraded. Its also good because then if you ever wanted to do a mini-me swap later on and really get the compression up there, you already have the pump upgrade
There is NO WAY anyone is going to build an NA B16 that is going to require so much fuel a stock fuel pump couldn't keep up.
B16's just don't move enough air, plain and simple.
you'll be fine with the stock fuel pump for your build. and if you haven't bought the injectors yet, you're better off with 310cc injectors. If you already ordered the 450's, its still ok since you're gonna get it all tuned anyways.
Red D Dragon
21
Mar 17, 2004 12:05 PM
